Waldon 5000
/ Waldon 5000 #1
butcherpl
Chicago
Waldon 5000
I own a loader, waldon 5000. I have to change the starter and i ran into a problem. After removing 3 nuts form the starter mount, I can't wiggle the starter out form the bay. First time doing this job. On my way I have the oil filter nest and the dipstick. should I remove them first before trying to take out the starter? any help is appreciated! Thanks!
/ Waldon 5000 #2
first welcome to the forums what i can find on this is it has a perkins motor any way you can post picture or pictures of the starter did one recently on very large wood chipper the replacement was about 1 inch longer customer tried for 2 days to install so i went to his place and all i had to do was remove dipstick tube and bolt it up but had to be in a straight line to housing to install or remove good luck
/ Waldon 5000
Thanks Mitch for the respond. I will try to do that first, I would post pictures, but currently the loader is out of state. will have some next week when i get there and try this job again!
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
EZ Trail 3400 (A63689)
10in. Auger Bit (A65640)
10in. Auger Bit...
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
Gehl RS5-19 (A62177)
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
