Dirty hydraulic hoses
/ Dirty hydraulic hoses #1
jd4310man
Scottdale, PA
Yanmar VIO27-3, New Holland LX885, John Deere 855 C.U.T.
I got a Yanmar mini excavator and I'm replacing the final drive motors. Anyway a long story short, the old motors were pulled off and the machine sat for a while and now the ends of the lines are dirty. Before I install the new motors (Big $$$) What is the best way to clean out these hoses so no dirt gets in and contaminate the new motors?
/ Dirty hydraulic hoses #2
The best but not the easiest would be to disconnect the hoses at the source and then somehow run some fund through them from the source end to the motor.
Thats kinda what I was thinking. There is sand and grit that is all over the fittings and i dont want any of that to wind up in the new motor. Would it be a bad thing if i would give it a good pressure wash and then take the hoses off?
/ Dirty hydraulic hoses #4
I'd cap off the hose ends, then pressure wash, then force some hydraulic fluid through each hose until it comes out clean, and use compressed air to blow out the hoses too. Water is as bad as sand,dirt, etc. to hydraulic pumps/motors. You need nearly surgically clean environment or you will damage those expensive new motors. The hoses must be clean and dry before you hook them up.
/ Dirty hydraulic hoses #5
i would take a couple can of brake cleaner and using the spray nozzle tube insert tube into hose holding hose upside down spray so all fluid and cantaminants run down and out hose
/ Dirty hydraulic hoses #6
Last time I checked, brake cleaner had a disclaimer about being bad for rubber. Been a while since I used it and it may have changed.
I know that hydraulic hoses are not cheap but have you considered a straight replacement? With the price of motors, hoses are cheaper. If replacement costs are through the roof for new hoses (which might need changing sometime in the near future anyway?) I would pull the hoses and flush them from the cleaner end towards the dirtier end.
Good luck with it,
David from jax
/ Dirty hydraulic hoses #7
I clean hyd hoses by dumping quite a bit of gasoline in the hose and then blowing it thru with a big air nozzle. The gas gets rid of the oil so the dirt doesn't stick. I do it a couple times. Blow enough air thru so all the gas evaporates before you're done. Gas is pretty cheap, you can use a lot of it.
/ Dirty hydraulic hoses #8
Good luck with it,
David from jax
I agree, Brakleen is not good for rubber parts. You could use carb cleaner to dry out the inside of the hoses once you find a good solvent to flush them out with, prior to using the carb cleaner. As stated earlier, they need to be surgically clean before hooking to the new motors or any contaminants will do damage to the motors.
/ Dirty hydraulic hoses #9
Not saying you have to use this system but you could get a few of the projectiles and clean it out that way, I'm sure there's an adapter you could make to blow the projectile thru rather than having to purchase the gun.
I've used it before and it does work well, never stuck a projectile in a hose and they were running a very convoluted path, took out a lot of crap.......Mike
Cleaning Hydraulic Hose - YouTube
mrmikey, thanks for the video link! I never gave it a thought about all the dirt that comes from making a hose. Wonder how many new or rebuilt pumps get ruined because of a failure to thoroughly clean out the hoses before installation. I found this video on how to make a hose cleaner out of a 55 gallon drum. Importance of Clean Hydraulic Hoses - YouTube
/ Dirty hydraulic hoses #11
A lot, especially when it is a hydrostatic system. I just fixed a "new" unit that had never made a job and the customer put 3 pumps and 2 motors on it before giving up. The filtration was wrong and the unit including hoses were filthy. CJ
/ Dirty hydraulic hoses #12
You'll definitely want to cap off the ends of the system AND the ends of the new hose when you do replace your hydraulic hose. I know a lot of guys forget about capping off the ends of the new hydraulic hose or hydraulic fitting, but it's pretty important. I found a quick article on how to replace hydraulic hoses that you might want to give a quick read, here it is.
/ Dirty hydraulic hoses #13
You can clean the outside of the hydraulic hose with a rag or pressure washer, then disconnect the hose and run something through it, like clean air or a cleaning fluid. Here's an article I found about how to clean hydraulic hoses, maybe you can get some different ideas out of it.
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
Bomag Roller (A63689)
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
John Deere 4520 (A60462)
John Deere 4520...
