Purchasing a new BX23SLBR
/ Purchasing a new BX23SLBR #1
rickyb01
Mayflower
1976 Deutz 3006 1962 John Deere 1010
Getting a new subcompact with a backhoe and mechanical thumb with 3 pt hitch. The machine at the dealership has the quick connect at the front bucket and I can just about bet I will never take that bucket off. They will have to go get a machine at a sister store that doesn't have the quick connect. For 350.00 would you purchase the quick connect even though I doubt I will ever use it. Sorry but don't have a lot of time to research and looking for some quick response. Thanks Rick
/ Purchasing a new BX23SLBR #2
Having the ability to do something in the future has got to be worth $350... if you never use it, no problem. But it is very likely someone will find it handy.
/ Purchasing a new BX23SLBR #3
In my mind the most likely attachement would be pallet forks. Is that something you would ever use?
/ Purchasing a new BX23SLBR #4
What, you can't wait a few days to save some $$ ? It would be worth the extra cost for most folks, but if you're convinced it's not needed, try being patient.
/ Purchasing a new BX23SLBR #5
Even if you don't use it, it will fetch some extra dollars at trade in time, so long term cost would be less than the full $350.
/ Purchasing a new BX23SLBR #6
You know your needs better then I do but I would get it. $350 is a small price to have the ability to switch implements easily. Do you think you'd ever have a need for a grapple? I was suprised at how often I switch between grapple/forks/bucket and I only have a pin style QA.
If you see yourself switching between loader attachments at all in the future it's definitely worth it, plus it's usually cheaper to get at time of purchase.
If you don't like it I'm sure you could find someone else with a BX that would be willing to buy it off you and switch buckets.
/ Purchasing a new BX23SLBR #7
For $350 it is Kubota's proprietary pin on bucket, not SSQA.
Give it a pass. Operating in brush I had one Quick Link pin pull out resulting in a $1,200 FEL repair, fortunately all but $250 covered by KTAC insurance. This was on my last Kubota, a B3300SU.
Rushing a tractor experience is not a good idea. Most buy too light and regret it.
/ Purchasing a new BX23SLBR #8
The Kubota site only list only the pin on bucket or the ssqa so I was assuming it was the ssqa since it wasn't specified.
I wouldn't be afraid of the pin style QA, not sure what happened with yours but the BX one seems to be pretty reliable.
Hopefully the OP can clarify.
/ Purchasing a new BX23SLBR #9
The Quick Link buckets pin on with pins similar to Lynch Pins. In woods work it is easy for brush to pull a pin loose, then one end of your bucket sags and the FEL arms bend.
OP will be better off without Quick Link bucket and $350 ahead.
SSQA is considerable weight subtracted from bucket capacity on a BX.
/ Purchasing a new BX23SLBR #10
Well I've been using a pin on heavily for the past 6+years and I've even made a few for other kubota models where they weren't offered.
Sorry you had a bad experience with yours.
I gave my opionion, I'll let the OP decide what's best for his use.
The place I purchased from had the quick connect bucket at their store and the one that didn't have the quick connect at a sister store. If I wanted the non disconnect I had to let them know by 12.00. So I posted on here trying to get some info for a quick decision because I had two hrs to decide. I went with the non-quick connect. Th bigger setback came when the dealership called at 5:45 to tell me there was no way I could get the middle mower for that tractor until fall. The mower itself has a serial number and is a separate item that is just not in stock anywhere. Because I can't get the mower I lose a 300.00 rebate Because the mower deck is considered an implement for that tractor. I have decided to get the tractor tomorrow and pay 300.00 more minus the cost of the deck and then buy the deck when mower comes in at end of year. I have a 60" zero turn so no big deal but a little upset over the 300.00 because that is not my fault they are not in stock or a warehouse. I also looked at the 2016 bx but liked the improvements the 2017 has. Thanks for all the advice. Ricky
Well I backed out of the deal on Saturday and really wanted some time to think over the whole situation of no mower deck being here until after the mowing season. The dealer wants 18,300 for tractor with FEL and Backhoe. Which I can finance for 0% and then when the mower deck gets here last this year I can just go up and purchase it for 2200.00. Is this something you guys would do? Or should I wait until the mower units get here and at that time the 0% interest may be gone. I have a cub cadet zero turn that was my dads before he passed away and I will always try and keep that lawnmower going because it was one of the few items he ever could afford and he was very proud of that little mower. Then I start thinking with not really needing the mower is the BX23SL what I really need. I only have a 1 acre yard but do own 50 acres with a cabin that I have to maintain a road on. I also have a ford 65 horse with a FEL at the farm but it has no backhoe. Any advice or words of wisdom?
/ Purchasing a new BX23SLBR #13
Get the BX with the SSQA. The SSQA will always bring the money back as well as make it a quicker easier sell if and when you ever decide to sell it It, the SSQA is so handy when one starts utilizing more aspects of their tractor, like forks, grapple, etc. Things one never considers using/doing start coming up when one gets the machine. Since you have a Zero turn you'll rarely use the BX for mowing at your 1 acre. If you really need it for mowing and considering the other property, get a Rear Finish Mower. Order it all at one time and finance with delivery when it arrives.
Also, stop the time pressure and shop other dealers to find what you think you want now and for price comparison. Financing changes at the first of each month and rebates/incentives change so one may be financially ahead or behind by doing something before the beginning of next month or waiting. It's a gamble. The 0% usually stays but terms change and incentives change, like tha additional implements for cheap/below dealer cost.
/ Purchasing a new BX23SLBR #14
Are there different model MMM`s for the BX23S...??? My dealer had several60" MMM`s in their stock for the BX`s.
So i`m just wondering why the OP is having a problem getting a MMM.
/ Purchasing a new BX23SLBR #15
There should be 4 different MMM's available. The 54" and 60" finishing decks, and the 54" and 60" drive over decks.
/ Purchasing a new BX23SLBR #16
Bet the Easy Over, or whatever they call them, are backorder.
/ Purchasing a new BX23SLBR #17
I have a new deck off my BX-25 in my garage.if that is the hold up. I am in Mi. very reasonable.
/ Purchasing a new BX23SLBR #19
I also for vote for getting the quick connect. As models evolve and change in the future, you may not be able to purchase it later. I stuff like that and tire chains as money in the bank. If you ever need it, it literally could be a life saver.
Thanks guys. The mower I was talking about is the drive over and yes they are on backorder. I think I will wait until they become available before making a purchase. I also think I will get the quick connects also. Thanks again for all of your advice. Rick
New/Unused Receiver Hitch (A61166)
New/Unused...
8063 (A61166)
8063 (A61166)
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
LAND PRIDE CB1060-60" HYD 4N1 BUCKET (A62130)
LAND PRIDE...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
