Pat's Easy Change Ordered
/ Pat's Easy Change Ordered #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Finally ordered my Pat's Easy Change. Shopped online and found the best price to be from Rural King. Easy Change with spreader bar and three extra sets of washers was $181.96 plus $10.92 tax for a total of $192.88. No shipping charge! It has already shipped and should be here tomorrow or Monday. I will let everybody know how ordering from Rural King works out.
RSKY
/ Pat's Easy Change Ordered #2
Just started using mine.
So far, so good.....and makes hooking up so easy.
One learning curve: My post hole digger (PHD) is Cat 1 (can't change welded pins) and the PAT's are CAT 2. No problem says I, just add a conversion bushing to the PHD pins, now they're Cat 2 and off I went.
The PHD in rocky ground(!) was a good test for Pats.... BUT I forgot and used the CAT 2 "special 1/2 washers" that came with the Pat's, that protect the retaining clip that goes through the PHD's pins. What I didn't notice is there's just enough slop in those washers on the Cat 1 pin that when the PHD finds a rock and bangs around, the washer can sneak past the bottom of the retaining clip and unlock the clip and send it flying. :eek: Now I'm watching a rotating post hole digger banging around in a hole & it's only hanging to the tractor is by the top link and the PTO. This 1 point hitch doesn't work well!
I went and bought some "full circle" washers with a 7/8" opening (Cat 1) and used them and no problems.
/ Pat's Easy Change Ordered #3
RSKY
Pat's Easy Change is $169.99 from Agri Supply.
No Tax,..... but there is a shipping cost.
Agri Supply is a FIRST CLASS COMPANY to deal with!
/ Pat's Easy Change Ordered #4
I have a set of Pat's QH, but I have been using my H.F. Q.H. for so long, I decided to go back to that. I have the Pat's on Craig'sList for $125. No bites yet. I should use Ebay, but I hate the monthly fee they charge.
/ Pat's Easy Change Ordered #5
Do yourself a favor and buy some grade 8 bolts to replace the ones they ship with, they are super cheap and can bend. mine bent and they shipped me gold color grade 8 which are so much stronger. The manufacturer has awesome customer service but using a stronger bolt would prevent things. The easy change system rocks.
/ Pat's Easy Change Ordered #6
Since when has E-Bay been charging a "monthly fee"?
/ Pat's Easy Change Ordered #7
Grade 5 bolts should work just fine also.
The Rural King total delivered was $192.88. Agri Supply did not have free shipping. When all was totaled up they would have been $204.77. Or nearly twelve dollars higher for the same thing. So I went with Rural King.
RSKY
/ Pat's Easy Change Ordered #9
Mine worked fine with a bush hog planter, disc, tiller etc but didn't work well with a box blade that's when the bolts bent. Just a suggestion
/ Pat's Easy Change Ordered #10
I'm not very familiar with Pat's easy change system but one might be careful not to use too strong a bolt causing a more expensive failure if it doesn't bend/shear.
/ Pat's Easy Change Ordered #11
The other damage that would occur would be that it strips the threads out of the Pat's hitches. Then I guess it would be time for larger bolts.
/ Pat's Easy Change Ordered #12
That's where I got mine. They include the drag link in the price where some other suppliers charge you about $18 more for it. Without the link you loose half the advantage of the system.
/ Pat's Easy Change Ordered #13
Unless you have telescoping stabilizers.
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Rhino SE415A (A64126)
