Stuck with a BH92 backhoe I can't use
   / Stuck with a BH92 backhoe I can't use #91
And that is one reason why its against the rules on to list the name of a "problem dealer" on TBN...
Aaron Z
Or the dealer was reading TBN and figured he better get his act in gear or he'd be soon outed. :D. TBN is a loud megaphone.
   / Stuck with a BH92 backhoe I can't use #94
I understand not to mention a so-called bad dealer but wonder if we can mention a good dealer? Seems that should be OK?
   / Stuck with a BH92 backhoe I can't use #95
No issues with bragging about a good dealer that I know of.
Aaron Z
   / Stuck with a BH92 backhoe I can't use #96
Congrats on getting your BH sorted out. Now go enjoy it.
   / Stuck with a BH92 backhoe I can't use #97
Your new BH looks great. Each time I see someone with a new BH92, I feel compelled to remind them to READ the Manual. There is a small note in there saying not to use the rear remotes while the BH is mounted. What they mean is you cannot use a rear remote if your BH is plumbed to the Power Beyond port. If you do, it will wreck seals on the BH hydraulic block. (Normally you would not be using rear remote at same time as BH, but if you have a power-angle snow plow or a hydraulic auger on the front, disconnect the BH hydraulics.
   / Stuck with a BH92 backhoe I can't use #98
A good reminder.
   / Stuck with a BH92 backhoe I can't use #99
A good reminder.
Should be more than just a small note. One whole page with a big WARNING/CAUTION tag would be more appropriate with an explanation such as yours. :thumbsup:
   / Stuck with a BH92 backhoe I can't use #100
Congrats on getting your backhoe sorted out. Make sure to grease all the zerks and check for loose bolts.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Mini Forks (A50322)
Mini Forks (A50322)
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
