Question about Japanese Beetles
/ Question about Japanese Beetles #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
Last summer Japanese Beetles did a lot a damage to leaves on 4 fruit trees and 2 young pin oaks in my yard. By the time I noticed them and sprayed insecticide, they had severely damaged lots of leaves. In fact, by August all the leaves on one of the pin oaks were gone. All the trees came back this spring and looked healthy.
Well recently the little buggers came back with a vengeance. I noticed the situation a little quicker this year and sprayed before they had reeked as much havoc as last year. Have I likely killed them before they have had a chance to lay eggs in the bark/soil or wherever they deposit them? I'm hoping that next year I don't have to fight this battle, but that's probably wishful thinking.
/ Question about Japanese Beetles #2
I have been using the Bonide Japanese Beetle traps. I just emptied a bag of about 10,000 and put a new bag with pheromone and already have a couple of hundred in there. Never Ending Battle !!!!!!
/ Question about Japanese Beetles #3
Here is a picture of them.
Here is the new bag I just put up 30 minutes ago:
Obviously the traps work. My only question is am I drawing them onto my property?
/ Question about Japanese Beetles #5
We've wondered that in the past, too. They're obviously there for the trees anyway, but you have to wonder if the traps just make it worse. Starting to see a lot of those boogers around our area this last weekend, too.
/ Question about Japanese Beetles #6
If you have that many beetles, you likely have a grub problem in your yard. Do you notice alot of mole activity? Or areas of yard dying off?
Bot much you can do to prevent beetles from flying on to your property from neighbors, but kill the grubs in your yard and you will kill the beetles that hatch on you property
/ Question about Japanese Beetles #7
I don't think so. They come every year around here. From what I understand they start as grubs in the yard then come out in June as beetles. So I guess the thing to do would try and kill the grubs in the ground before they lay eggs. I have never looked into getting rid of them as grubs. All I know is they have been around every year for as long as I can remember. Maybe someone will chime in on how to get them while they are grubs.
/ Question about Japanese Beetles #8
We also use Neem Oil around are plants. The Neem Oil works well and supposedly once the beetle gets in the oil it will kill the larvae before they get a chance to lay the eggs.
I did a little U Tube research and I think the best strategy is to get them when they are grubs. It appears that the best time to put out grub insecticide is late Aug to early Sept. Ill do that and hope for the best next June.
/ Question about Japanese Beetles #10
Get some 'milky spore' powder .....it's a bacteria (Bacillus popillae) that attacks the grubs in the ground. You put it out once, as the grubs die, they spread the spore in the ground, so it pretty much self perpetuates the bacteria. Stuff isn't cheap, and it takes a couple years to begin to control effectively, so you'll have to continue conventional insecticide spraying, but it is the only long term, effective control method.
Milky Spore for Grubs, Milky Spore Grub Control Granules - Free Shipping
/ Question about Japanese Beetles #11
/ Question about Japanese Beetles #12
When I first had the problem, the local nursery said the best solution was to buy the traps and give them to your neighbor a few hundred yards away. I was told that the traps do work great, but will attract the beetles.
My solution was by accident. Chickens! I have not had a beetle problem since I got chickens.
1976 T/A RGN Low Boy Trailer (A61568)
1976 T/A RGN Low...
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
2015 19ft. Yamaha SX190 Boat with 17ft. S/A Boat Trailer (A61569)
2015 19ft. Yamaha...
2015 MACK CXU613 T/A 6X4 MID ROOF TRUCK TRACTOR (A59910)
2015 MACK CXU613...
Invoices (A63116)
Invoices (A63116)
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
