DIY weed wiper
/ DIY weed wiper #1
droy
Southwest Louisiana
NH Boomer 55, ZD1211
Just curious if anyone has ever built a 3 pt mounted, or pulled weed wiper that works, & doesn't leak, drip, etc.
Have about 9 ac of pasture, thick with different weeds but also some grass.
/ DIY weed wiper #2
Search, Weed Wiper .
/ DIY weed wiper #3
I have a feeling that if you can design one that is wet enough to transfer the herbicide to the plant in question, then it will drip some,
as most either use cotton rope or a cloth that wicks the herbicide mix out of the tank and siphons to the bottom of the tube/tank to make contact, with product to be wiped, yes to capillary action and the gravity it does siphons to the bottom of the wipe medium, and since it is lower it over loads and drips,
for example: take a look at this page, how to siphon water with a napkin between glasses, Christmas napkin siphon - Science Tricks - Surfing Scientist - The Lab
this here company makes a one with a sponge material, and drips the chemical on or in it, it is about the only way I would know of is to be able to control the flow to the wick medium and to have a extra absorbent material so one can get it wet enough and then not over fill it, Weed Wipers
/ DIY weed wiper #4
Agrisupply has 5-ft wiper modules for about $100
String Wing, 5' Wick Appicator, Chemical Applicator | Agri Supply, 71934, Rope W
I have three of them that attach to the FEL on my Mahindra 5525
Use it to apply glysophate (generic Roundup) to my 6 acre hayfield to control fiddleneck weed.
I order 2.5 gal containers of concentrate from Home Depot at $49 each. Order two of them since HD has free delivery for orders over $75.
Good luck.
/ DIY weed wiper #7
I built a 10' wide wiper from parts supplied by Rodgers Sales Co., INC
It works well but slow. If you go too fast the weeds don't get a good dose. Mounted on the lip of the FEL. Couple of design changes I made was using test plugs to seal the ends and clamps to allow the wiper to be rotated while mounted. The test plugs are easy to open and rotating the wiper allows emptying the pipe into a bucket when finished.
/ DIY weed wiper #8
I too built a wiper with Rodgers Sales Co parts. The kit has the hard to find items and you supply the pipe and glue. The finished weed wiper works great.
/ DIY weed wiper
Thanks to all for the replies, while I mentioned that my pasture has grass in it, I neglected to mention that I would like to just kill the weeds, saving the grass, which rules out a sprayer.
Forget which company makes a wiper that has sponge glued to a pipe and rotates to keep the sponge wet. Like that idea and tempted to try using PVC pipe and some canvas strapping similar to the winch straps truckers use. The canvas would be alot tougher than sponge, but not nearly as absorbent. We have a rubber and gasket store in town that handles a wide variety of materials think I'll check with them for suggestions. That just leaves figuring out the framework and mechanics that would rotate the pipe......sheesh, this DIY stuff can be a mental strain for Joe Sixpack- buying a finished product is beginning to appeal to me. lol
/ DIY weed wiper #10
In a pasture that has both weeds and grass it can use a spayed. It's the chemicals that you use. A broadleaf weed killer will only kill the weeds not the grass unless you have a broadleaf type of grass. Using a lawn as an example I have Bermuda grass growing. I can pour a broadleaf weed killer on it directly and it won't do anything to the grass.
/ DIY weed wiper #11
This is exactly correct. Have sprayed pasture with a 2-4d solution for years. Unless you have a major spill in one spot it leaves the grass unharmed. Only kills "broadleaves" but that does include clover. Here is a link to what I use. Ag Spray Equipment - Farm, Lawn, Garden, Spot Sprayers, Parts, Pumps, and Tanks.
And as far as I am concerned forget about using any of the purple dye to see what has been covered. It is expensive and for what it costs you can afford to overspray a little or wait a week and spray what you missed. Another thing is to get as big a tank as your tractor will handle. Tramming back and forth to refill with water takes more time than the actual spraying.
/ DIY weed wiper #12
I can be slow. The manufacturer of my wick applicator recommends two passes in opposite directions to be sure the weeds get wiped. With 15-ft wide applicator, I can treat my 6 acre hayfield in about 3.5 hours.
/ DIY weed wiper #13
Is there a reason these are all on the front? Seems you'd then be able to track the glyophosphate elsewhere.
One of the reviews mentions tracking it onto the grass and then says "but I'm not sure how you'd avoid it"... uh, move it to the back of the tractor?
/ DIY weed wiper #14
Is there a reason these are all on the front? Seems you'd then be able to track the glyophosphate elsewhere. One of the reviews mentions tracking it onto the grass and then says "but I'm not sure how you'd avoid it"... uh, move it to the back of the tractor?
Your tires run down the grass and it doesn't get wiped so you'd have streaks in your field everywhere you drove.
/ DIY weed wiper #15
Yep. That's it.
/ DIY weed wiper #16
One of my friends made a very simple weed wiper out of a backpack sprayer. He just wrapped a cloth diaper around the nozzle and went out and wiped his weeds. Worked great and he didn't have to buy anything.
/ DIY weed wiper #17
Gotcha. I guess mine are pretty low and pop back up so it wouldn't be a big deal. Wipers are primarily for being able to keep the grass underneath?
/ DIY weed wiper #18
That's one way. I just fill a scrub bucket with glysophate mix and use an old squeegee mop as the wiper to spot-treat weeds in the landscaped areas around the house. Works fine--no appreciable carryover if you're careful and don't slop herbicide all over the place.
/ DIY weed wiper #19
/ DIY weed wiper #20
hosspuller- it the Rogers kit a gravity feed arrangement?
Thanks- Oldstuff
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED IRANCH...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
