Starting hay season 2017
/ Starting hay season 2017 #22
Very nice. That is a big load for that little tractor.:eek:
Yes we go very very slow in low range to get to the house. Its about 1/4 mile to the barn. You cant see it, but I keep the landing pads on the trailer about 3 inches off the ground while moving, so if there is an issue it sits down. So far moving it has been very stable. With three layers there is 108 bales on the trailer. Weight of the load is roughly 5500 lbs. 3pt picks it up easily. Believe it or not the tractor breaks will stop this load, as well as just backing off on the go peddle. Its on tough little beast.
/ Starting hay season 2017 #23
That seems like a lot of tongue weight for that tractor but it sounds like you got it worked out. using the tractor versus a truck makes it a lot easier.
/ Starting hay season 2017 #24
You guys out west are fortunate to be able to stack on concrete. Back here there is too much moisture in the winter and the condensation gets you with molding the bottom.
/ Starting hay season 2017 #25
Ever here we get ground moisture. I use wooden palletts
Looks like we're going to hit our first 100 degree day. Fields look terrible. Going on 20+ days since first cutting and I doubt that I'll be getting very much more hay than before.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
SKLP SK-HJ6 40' 6 Section Storage Shelves (A60463)
SKLP SK-HJ6 40' 6...
