Tractor Sizing Mahindra 1533 and Bush Hogging
/ Mahindra 1533 and Bush Hogging #1
Morriston Florida
Mahindra 1533
I spent a great deal of time hogging 15 acres with a 5 footer looked good after but it was a strain on me.
Does anyone feel that a 6 foot would work on the 1533 not to hilly but ?
Thanks all.
/ Mahindra 1533 and Bush Hogging #2
My two cents is a five footer is about max for your tractor. Guys, correct me if I've wrong, I'm sure not a brush cutter expert, but I think you are maxed out.
/ Mahindra 1533 and Bush Hogging #3
Thanks all.
Go for it, my 1533 handles a six-footer no problem. I cut rough farm fields with it, knocking down 1 1/2" saplings and bushes in addition to hood high grass.
It's great because the cutter is wider than the tractor wheels (and wider than a 5 footer)
Brian
Brian thanks you've solved a problem and the width is perfect again I'll post a picture but it's pretty dirty I'll take a lead from you and clean mine up!
I have really enjoyed the 1533 shuttle.
/ Mahindra 1533 and Bush Hogging #5
My just happens to be less than a year old and I did bump my wife's car out of the garage so that I could deter theft which happens to keep it clean looking. Now she says we should build a barn, hmm sounds like a good idea.
I originally was looking at the Max26, but wanted something just a bit bigger. Then they came out with the 1526, which I considered, but the PTO power was less than the that of the Max...not by much, but I couldn't wrap my head around that scenario, I was concerned about PTO. So I was all set to buy the Max26 and my wife had another grand idea, she told me that as soon as I got it home, I'd regret that I didn't have something bigger ...so ... I bought the 1533 and since has respectable PTO, I had an idea to go for the six foot because I knew it would handle it... Which, as stated earlier, it does.
/ Mahindra 1533 and Bush Hogging #6
The shuttle likes it much better but both run them.... we run 5fters on even 26xls
2022 DODGE RAM 2500 SERVICE TRUCK (A60736)
2022 DODGE RAM...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
2012 HEIL (A60736)
2012 HEIL (A60736)
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2019 FREIGHTLINER 126 SLEEPER TRUCK TRACTOR (A59906)
2019 FREIGHTLINER...
