What have you messed up, with your tractor? Including ROPS into garage...
   / What have you messed up, with your tractor? Including ROPS into garage... #221
I was loading wood chips into the bed of my old truck with the bucket high enough to clear the side when the dang gophers suddenly dug a hole in line with one of my wheels causing me to suddenly dent the top edge of the bed as the one wheel :mad:sunk down.
Are you familiar with the demise of the bulldozer in the movie "Tremors"??
Did it look like that?? :confused2:
Tremors Official Trailer #2 - (1990) HD - YouTube
   / What have you messed up, with your tractor? Including ROPS into garage... #222
I've had the corner of a house with siding , shift over from frost I guess :rolleyes: and crack the siding while I was plowing.:mad: We have bad frost here.:cool:
   / What have you messed up, with your tractor? Including ROPS into garage... #223
When I first got my M4700 it had a nice heavy duty steel canopy.
attachment.php
After a couple months of use my son decided to trim some tree branches and gave is a raised eyebrow.
Note leading left corner of canopy.
attachment.php
So when I decided to take the tractor from Alexandria, Va to Mississippi I took the canopy off.
attachment.php
Which was just as well, because my prime pickup bed unloading area is in a shed where the ROPS just BARELY clears.
attachment.php
And my woods are fairly thick with a lot of vines and a canopy would be a hindrance.
attachment.php
   / What have you messed up, with your tractor? Including ROPS into garage... #224
I have a friend who was cutting land and went between a power pole and guide wire going to the ground and ripped the canopy off. The guy he was helping questioned him why would you go through there? He said I did it the other day with the cut-a-way hare and made it, he said that explains why the chunk is missing from the pole, he hung it with a disc, lol.
   / What have you messed up, with your tractor? Including ROPS into garage... #225
495403d1484571389-what-have-you-messed-up-8x6sam_0798-jpg
495399d1484569929-what-have-you-messed-up-picture-118-jpg
495401d1484569987-what-have-you-messed-up-20140427_103025-jpg
495400d1484569974-what-have-you-messed-up-m4700-rops-clearance2r-jpg
495404d1484572063-what-have-you-messed-up-img_20151207_150524186_hdr-jpg
The tractor loaded on the trailer with bucket forward looks good!
The tractor loaded with bucket aft looks horrible! Seems like way too much weight is on the hitch.
   / What have you messed up, with your tractor? Including ROPS into garage... #226
When I bought my DK40 it came with a sun roof. Which was great. But a real problem when needing to go between pine trees 3m apart.
On completion of my new shed I removed the sunroof, because insufficient clearance with sunroof. Now the clearance is exactly 13mm, (1/2 inch) and as for the shreaded sunroof... I wear a sunhat instead (you know them cowboy hats).
Trouble with cowboy hats... insects like to take a ride in the shady area. Yesterday it was a persistent grasshopper.
   / What have you messed up, with your tractor? Including ROPS into garage... #227
This thread went cold lol, any new and funny stories?
   / What have you messed up, with your tractor? Including ROPS into garage... #228
This is one those threads where you really one want to post one 'aw****' pic/story. Otherwise others will be raising an eyebrow about your pace of learning. :D
   / What have you messed up, with your tractor? Including ROPS into garage... #229
This thread has saved me from quite a few of those moments lol.
   / What have you messed up, with your tractor? Including ROPS into garage... #230
I put two nice holes in the garage drywall with the 3 pt hitch of my brand new Kubota. Oops. I got them patched and painted before the wife ever even knew. ;)
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2014 Freightliner M2 (A55973)
2014 Freightliner...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2022 BOBCAT E60 R2-SERIES EXCAVATOR (A52709)
2022 BOBCAT E60...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
