What have you messed up, with your tractor? Including ROPS into garage...
   / What have you messed up, with your tractor? Including ROPS into garage... #221
I was loading wood chips into the bed of my old truck with the bucket high enough to clear the side when the dang gophers suddenly dug a hole in line with one of my wheels causing me to suddenly dent the top edge of the bed as the one wheel :mad:sunk down.
Are you familiar with the demise of the bulldozer in the movie "Tremors"??
Did it look like that?? :confused2:
Tremors Official Trailer #2 - (1990) HD - YouTube
   / What have you messed up, with your tractor? Including ROPS into garage... #222
I've had the corner of a house with siding , shift over from frost I guess :rolleyes: and crack the siding while I was plowing.:mad: We have bad frost here.:cool:
   / What have you messed up, with your tractor? Including ROPS into garage... #223
When I first got my M4700 it had a nice heavy duty steel canopy.
attachment.php
After a couple months of use my son decided to trim some tree branches and gave is a raised eyebrow.
Note leading left corner of canopy.
attachment.php
So when I decided to take the tractor from Alexandria, Va to Mississippi I took the canopy off.
attachment.php
Which was just as well, because my prime pickup bed unloading area is in a shed where the ROPS just BARELY clears.
attachment.php
And my woods are fairly thick with a lot of vines and a canopy would be a hindrance.
attachment.php
   / What have you messed up, with your tractor? Including ROPS into garage... #224
I have a friend who was cutting land and went between a power pole and guide wire going to the ground and ripped the canopy off. The guy he was helping questioned him why would you go through there? He said I did it the other day with the cut-a-way hare and made it, he said that explains why the chunk is missing from the pole, he hung it with a disc, lol.
   / What have you messed up, with your tractor? Including ROPS into garage... #225
495403d1484571389-what-have-you-messed-up-8x6sam_0798-jpg
495399d1484569929-what-have-you-messed-up-picture-118-jpg
495401d1484569987-what-have-you-messed-up-20140427_103025-jpg
495400d1484569974-what-have-you-messed-up-m4700-rops-clearance2r-jpg
495404d1484572063-what-have-you-messed-up-img_20151207_150524186_hdr-jpg
The tractor loaded on the trailer with bucket forward looks good!
The tractor loaded with bucket aft looks horrible! Seems like way too much weight is on the hitch.
   / What have you messed up, with your tractor? Including ROPS into garage... #226
When I bought my DK40 it came with a sun roof. Which was great. But a real problem when needing to go between pine trees 3m apart.
On completion of my new shed I removed the sunroof, because insufficient clearance with sunroof. Now the clearance is exactly 13mm, (1/2 inch) and as for the shreaded sunroof... I wear a sunhat instead (you know them cowboy hats).
Trouble with cowboy hats... insects like to take a ride in the shady area. Yesterday it was a persistent grasshopper.
   / What have you messed up, with your tractor? Including ROPS into garage... #227
This thread went cold lol, any new and funny stories?
   / What have you messed up, with your tractor? Including ROPS into garage... #228
This is one those threads where you really one want to post one 'aw****' pic/story. Otherwise others will be raising an eyebrow about your pace of learning. :D
   / What have you messed up, with your tractor? Including ROPS into garage... #229
This thread has saved me from quite a few of those moments lol.
   / What have you messed up, with your tractor? Including ROPS into garage... #230
I put two nice holes in the garage drywall with the 3 pt hitch of my brand new Kubota. Oops. I got them patched and painted before the wife ever even knew. ;)
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
2016 KENWORTH W900 DAY CAB (A57880)
2016 KENWORTH W900...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
