2240 Sun gear Lock Plate
/ 2240 Sun gear Lock Plate #1
mtDanE
JD 2240, JD 1010u JD1010r, JD 420 l&g, JD 110 l&g
Hey all,
I hope this it a quick question. I started hearing a noise from the Transmission, long story short, it ended up being the lock plate in the left axle that holds the planet pinion carrier to the axle shaft. the gears chewed it up to just slivers. It looks like the short axle stub shaft is all the holds it there. but I don't have a lot of faith that it is all there is to it. if that is it I do not know how it feel out to begin with or was it a sloppy repair job from before. It's #29 in the image - attached.
Thanks for any insight.
Thanks Dan
/ 2240 Sun gear Lock Plate #2
Hey all,
Thanks Dan
I've seen some that have a oring that holds it down on top of 12 point bolt head. I've seen some that just sit in top. I've always put a oring to just hold in place for install
/ 2240 Sun gear Lock Plate #3
Set the dragtorque on the bearings ...then install lockplate and undo the bolt till it lock that plate in its place
Thanks guys, I ended up backing the bolt up as suggested to hold the plate in place as I assembled it. Dan
New/Unused ATS Hydraulic Shop Press (A65583)
New/Unused ATS...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
213064 (A64276)
213064 (A64276)
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
