International TD 6
/ International TD 6 #1
rustydollar
Ca
Satoh S650G
This old TD6 just waiting for some fresh fuel and a new battery.
/ International TD 6 #3
For some of what I see I think you are an optimist!!
I bought an old Michigan loader once that died on the spot over water in the fuel they had burnt out the starter trying to get her running and left it, it sat so long the tires half flat had sunk into the ground to the rims.
I had the starter repaired, hung a jerry can with fuel onto the side, aired up the tires after she fired up then obtained a travel permit and drove her home to my yard where I used it for the next 5 years to pile scrap cars and load semi trailers out with loose scrap.
Diesel engines are amazing in that they can sit idle for years without seizing up, large boats and ships having thousands of gallons of diesel laid up for years will have someone come in to polish the fuel.
In my case adding a jerry can with fresh fuel was enough to get that 4/71 Detroit diesel purring again.
Fuel polishing - Wikipedia
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
