backhoe ripper, trailer hitch
/ backhoe ripper, trailer hitch #1
bandaidmd
DelMarVa
kubota b2620,b8200
Just got my bx expanded quick coupler for my backhoe and decided that now that its so easy to swap tools i need some. First up is a ripper , the u channel mount is 4"x3/8 thick angle doubled up and lap welded the tooth is a replacement box blade scrcifier . I milled a slot in the doubled up portion so both top and bottom of the tooth could be welded. I welded a piece of 3/8 x1 flat bar on the front and cut in some teeth freehand with a cutoff wheel. The hitch is a prefab receiver tube. The mounts are a 1"roundbar welded directly to the square tube. The other end is a piece of 1"id pipe for the pin to pass thru. I didn't have any of that thick wall tube so i bent a piece of 1/8"x2 flat and welded it over the pipe as a reinforcement. 20170528_104939.jpg20170528_124023.jpg20170529_145506.jpg20170529_145525.jpg20170529_145626.jpg20170529_145209.jpg
/ backhoe ripper, trailer hitch #2
Nice job man....Like your mini mill. Its on my "To Buy" list.
Instead of putting a receiver on my backhoe I put one on my front bucket. Use it all the time. Probably one of the most convenient upgrades I've done.
/ backhoe ripper, trailer hitch #3
Nice job. I like the double angle to make the mount.
I would suggest some bracing of the tooth to the mount. There's quite a bit of force/leverage on that joint and I question if the way you've got it will hold up.
i have one mounted in the same spot but even with the backer plate it has bent the top lip of the bucket. I have built a 3ph mount onto a ssqa plate that i use my tbar hitch on the front. Having the hitch back closer makes a big difference.
it passes thru the doubled up angle and is welded top and bottom. Theres also a 1/2 x1 piece that serves as an extra gusset. Pretty sue that mystery metal chinese shank will break or bend before it dislodges from the mount.
/ backhoe ripper, trailer hitch #7
I used a heavy piece of angle and then attached the hooks and reciever to that. I move around some really heavy trailers alot and sometimes I get lazy and just leave it on while im digging\moving material and I have yet to bend anything after 3 years. Its pretty strong with the angle.
thats a better angle lol. i just used a backer under the lip, i like your version.
/ backhoe ripper, trailer hitch #9
How well is that mini mill work for making 1"+ holes? Do you just use regular drill bits or a different kind of cutter thanks?
Mark
It works fine and is precise but its slow going about a .012 cut at a time per side (.024 dia) . I originally marked each side and drilled 7/8" holes on a regular drill press (need 1") before welding the half's together but they shifted a little bit just as i thought they might. By finish cutting to size on the mill i was able fix my error and the pins were perfectly aligned. The cutter in the picture is a boring head that has a screw that kicks the cutter off center, you could start with a 1/2" hole just big enough for the cutter to get inside of and bore a perfect hole up to 8" . These little machines will start to chatter way before that and the more offset the cutter the less cut you can take but it can be done. I have always wanted a lathe and got a old 9" atlas a couple years ago and that led to to learn about milling. To think back of all the crap i have somehow managed to put together and repair over the years without those tools makes me wish i have bought them years ago.
/ backhoe ripper, trailer hitch #11
Ok, thanks for the reply. I am building a small tow behind backhoe. I'm using a drill press and bi-metal hole saws to make the required holes. It is far from precise, but close enough for what I need at the moment. I am definitely interested in buying a lathe or other machine so I can do more accurate work. I'm hoping to find a smaller one that I can learn on. Thanks.
/ backhoe ripper, trailer hitch #12
Nice job on the build. I like the quick attach feature and may have to work on that for mine. I built a ripper for my hoe last year and discovered it's the best way to remove stumps so I'm sure you can't wait to try it out. Like you, I used a box blade scarifier I bought at TSC. My only comment would be that it appears your teeth are angled to cut on a downward motions. All the rippers I've seen cut on the upward motion which makes sense since you are pushing against the ground and not lifting the machine.
good catch on the teeth i noticed that too....right after i sat the cutoff wheel down and stood back to admire my work. lol It is what it is at this point.
Pick up a 12" drill bit that will reach both sides while it in the drill press as a pilot bit so your holes will be sure to line up opposite one another.
2025 28in Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in Forks...
UNUSED WOLVERINE 60" HYD DRUM MULCHER (A64281)
UNUSED WOLVERINE...
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
UNUSED RANCH HAND BRUSH GUARD (A64280)
UNUSED RANCH HAND...
UNUSED WOLVERINE LAND LEVELER (A64281)
UNUSED WOLVERINE...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
