Loader Side Dump Bucket on a Compact Tractor?
/ Side Dump Bucket on a Compact Tractor? #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Has anyone tried using a side dump bucket on a larger compact tractor? Most of those I've seen are designed for skid steers like the one pictured.
I realize there is a stability issue with using an implement like this on a fully raised compact tractor FEL. Also, the frame may not be designed to handle a heavy side load . The use I had in mind was to dump shot rock or rip rap over the edge of a bank. I'm building a terrace and don't have enough room to dump forward. The work wouldn't require the bucket to be more than a couple of feet off the ground. Anyone have any experience or advice?
/ Side Dump Bucket on a Compact Tractor? #2
I wonder I fit would be easier to build a mobile chute that you can dump into with your standard bucket.
I have an old 550 gal fuel oil tank I thought about cutting in half lengthwise for that purpose. The fabrication time to mount it on something movable would be a consideration though. The side dump bucket could be used for applying mulch in the future so it would be a multitask implement.
Thanks for your suggestion though.
Adams 5T Spreader (A63118)
Adams 5T Spreader...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
