John Deere 318 transmission
/ John Deere 318 transmission #1
Hjfowler
Member
Forest Hill, MD
John Deere GT275
My trans stopped working. I have hydraulics and power steering, but no trans. Here's what happened. I tried to use the pressure relief valves, but they were stuck. So I hit them with a small amount of WD-40. I was eventually able to open them with a small hammer. They were freed up. They popped back up when I started the tractor. Then I shut everything down and tried to depress them again, which I was able to do even though they were a little sticky. They popped back up again when I fired up the tractor, but the trans still isn't working. Could something be stuck in the valances causing them to be open even though the buttons on top are indicating closed?
/ John Deere 318 transmission #2
If everything was ok before tinkering with the valves I would simply remove the valves and inspect them before trying or assuming anything else.
Thanks. Everything was perfectly fine and I didn't touch anything else except for the valves.
Turns out the ball was stuck at the bottom of the valve on both valves. Cleaned it up and everything is working again.
/ John Deere 318 transmission #5
Glad it was an easy fix and you are up and running again.
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
2013 CATERPILLAR 259B3 SKID STEER (A65056)
2013 CATERPILLAR...
2015 Infiniti QX60 (A66738)
2015 Infiniti QX60...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
PALLET WITH 3 ELECTRIC CHAIN HOISTS AND ONE MANUAL CHAIN FALL OUTBOARD MERCURY PARTS MOTOR (A66738)
PALLET WITH 3...
