eMax 25 rear work light
/ eMax 25 rear work light #1
jjk454ss
Holland, MI
eMax 25s
Do they make a rear light for the eMax 25? Something with a bracket and wiring all ready to hook up? Or do I need to just find something that works?
/ eMax 25 rear work light #2
You might just have to build your own. I mounted mine up on the ROPS, two forward, one rearward.
/ eMax 25 rear work light #3
Your Mahindra dealer more than likely has some type of after market l.e.d.lighting. I just used some real nice cheap lights from Northern products and hooked them up to the wiring from the factory coming out the back of the 3016. Perhaps the Max has some auxiliary wiring as well. Because these lights only draw 1.5 amps per light, I hooked two of them up to the stipulated 3 amp wire coming out the rear of the tractor.
Thanks for the great ideas.
I need something closer the the rear, shining on the 3 point, so I'm not sure upon the ROPS is the best for my situation. I'll see what I can find that I can mount lower though. Thanks
/ eMax 25 rear work light #5
I have two rear facing pods, 1 facing down for the hitch and one facing further back so I can see what I am working. I also have a full light bar facing forward.
/ eMax 25 rear work light #6
I mounted mine on the several holes available at the rear shroud of the tractor on either side of the safety triangle and pointed them at the 3 pt.
Thanks
Love this idea, can you post a pic? Thanks
Found the easy/cheap solution today. All I need it for is hooking up trailers on the back of the barns where it's dark, so this magnetic light looks like it will work fine. I picked one up today to try it out tomorrow.
Rotating Magnetic LED Worklight
/ eMax 25 rear work light #11
That does look like a cheap and very slick solution if that is all you need it for. I installed LED lights on my Max26 for working in the dark, plowing snow, etc but that little light would be handy for just about anything. I might go pick one of those up now. Thanks for posting. :thumbsup:
It works great for me, just hooking up trailers in the dark, probably wouldn't be much good snow plowing of course though. But for $10, definitely a handy light, I may pick up a second one when I go back.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
