Mowing New Oregon Gator Mulching Blades Scraping Deck
   / New Oregon Gator Mulching Blades Scraping Deck #1
jerkyboy
Upstate NY
So I just got a set of Oregon Gator mulching blades to replace my worn out Kubota blades. I bought them for my 48" BX1500 deck because I read a lot of good reviews. They are much more beefy than the OEM units and appear to be of good quality. I was psyched to test them out today but as soon as I engaged the mowing deck I could hear a very slight rubbing of the deck. As soon as I started mowing and hit any uneven ground, the scraping was more pronounced. Major bummer:mad::mad: Anyone else have a similar or better experience? Hopefully I can return them for a refund...and just in case anyone is questioning, I definitely installed them correctly.
   / New Oregon Gator Mulching Blades Scraping Deck #2
I put some on mine (bx 1860 48")and had no trouble. They were not the part # for my tractor, Oregon didn't make one for it. I did it off measurements.
Unless you have a fine cut deck, I don't recall that Oregon makes a blade for your tractor.
Deck is a RCK48-15BX...x-ref'd part on Oregon's site and ordered three 391-617s per spec.
   / New Oregon Gator Mulching Blades Scraping Deck #4
Perhaps your spindles are worn allowing the blades to wobble? The blades sound great - I'd be inclined to pursue the problem before giving up on the blades. Besides, if you have worn spindles you'll probably be replacing those in the near future anyway.
   / New Oregon Gator Mulching Blades Scraping Deck #6
Do you see scraping? I know they make some noise compared to a flat blade but the teeth shouldn't make them tall enough to rub on the deck.
I would look at spindles being loose. As thick as they are I wouldn't expect the blades to be flexing much.
   / New Oregon Gator Mulching Blades Scraping Deck #7
Maybe your deck shell is bent.
Mine was, and my tractor is fairly new. I happened to notice it while changing blades and beat it back straight.
   / New Oregon Gator Mulching Blades Scraping Deck #8
How about a fender washer to move them down a bit.
One of the blades was scraping the deck a tiny bit...ground it down about a 32nd and working like a champ now. Thanks for the input.
   / New Oregon Gator Mulching Blades Scraping Deck #10
Glad you're set... Late in seeing this post, but I had a similar experience with my zd326 and Gator Blades several seasons ago. They were just barely nicking the deck and I just let it go. I recall it them "wearing in" after a few minutes, then a couple of deck flexes later stopped altogether. You are going to like these blades!
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
