1920 sooted up
   / 1920 sooted up #1
Twindad01
New Brighton PA
1990 new holland 1920
So took the exhaust manifold off and it was almost clogged off on most of the ports and really packed in the head part. Any idea what would cause this? My theory is it was bogged down a lot. My buddy says not running hot enough and wants to up the thermostat to a 195. Any and all ideas are most welcome
   / 1920 sooted up #2
Possible valve stem seals are leaking oil. Is it dry soot or wet/damp soot. Also could be excessive over fueling or a lot of idling time. How much blow-by does the engine have. A lot moisture getting into the exhaust from rain or setting in an excessive damp environment.
   / 1920 sooted up #3
Change your oil recently? Even new oil with a high ash level will form deposits in the exhaust manifold
   / 1920 sooted up
The soot seemed to be somewhat wet. Cant say about the oil change as it hasn't really been ran since we got it. Now it's torn down and going back together. It has 1160 hours on it.
   / 1920 sooted up #5
Once running again, I would check for deposits every 25 hours or so, limit idle time to a minimum, and keep the rpm's up while running.
   / 1920 sooted up #6
It's not being worked hard enough. You might also check the sir filter and see if it's clogged. That will make the fuel/air ratio too high and contribute to the problem.
2017 Ford F250 (A55973)
2017 Ford F250...
Kubota LX2620 (A53317)
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55315)
2023 Kubota U48-5...
