Oil & Fuel Fuel Additives, when or not too add
/ Fuel Additives, when or not too add #1
James Henry 01
Judah, Indiana - Mississippi Native
Kubota B2710
Hi,Guys...
I am wondering when is the best time to add fuel additives, and really when to add what certain additives for best results. After buying the tractor the gentleman handed me a bottle of Stanadyne and suggested
that i keep adding it to my fuel, which i have at each fill up.The question is should i, or should i not?? I recently picked up a bottle of the Stanadyne lubricate thinking that it might clean an lubricate at the same time. Summer is here practically and i wanted to cover my bases concerning the heat as well...what ever that i need to do to help that little sweetheart give me her best...She is working, shining and looking tractor model sweet....She deserves the finer treatments..lol
Hey....that obnoxious rattling noise coming from the ROPS just about drove me crazy!!! Well, we went to Lowe's and picked up 2- 4"x 5" vinyl repair kits that has adhesive on one side (cheap enough) cleaned then placed them around the front and the equally on both side then cut the bolt holes out for the bolts. Then Slipped the ROPS into place, and we slipped the front bolt's into the front bolt hole's to secure the weight of the ROPS system on each side and only tightening it down slightly. Then in the second bolt holes we slipped the bolts partially into the hole while aligning the extra washer's one on each side (washer's on the inside) while holding the correct washer size on the inside of the ROPS Bar so that the bolt can go through the washer allowing it to then tighten up with the rear retainer bolts of the ROPS system removing and excess play that also added the "Boot, Scoot & Rattle to our Orange Ladies". "And Wallah" no rattle or sanity lost! Just don't ask my wife concerning the sanity part...;-}
Happy Days and Happy Tractoring to you all....
james
/ Fuel Additives, when or not too add #2
Can't comment on Stanadyne products, but most folks add a winter product to prevent gelling, and some add a summer product for lube.
I generally use fuel additives in the winter only.
The best thing you can do for fuel is be careful how you store and filter.
/ Fuel Additives, when or not too add #3
Have a look through some of the "Similar Threads" at the bottom of this page.
Personally, I've started adding 50ml of "Fuel Doctors" additive to a full tank, but that's after experiencing a biological contamination in my tractor's fuel tank. It's a biocide + it breaks down contaminates to a microscopic level & suspends it in the fuel allowing it to pass through the entire fuel system to be burned up by the engine. It also adds to the fuel's lubrication properties and acts to stabilise the fuel for long-term storage.
The same product works in 4-stroke and 2-stroke petrol too. :)
/ Fuel Additives, when or not too add #4
Good fix on the ROP.
I use Power Service (white bottle) year round. Never an issue. Lubes the fuel pump and gives a cetane boost.
/ Fuel Additives, when or not too add #5
I use Power Service (white bottle) in winter and Power Service (grey bottle) in summer. I have never had an issue with fuel jelling since I have been using it.
/ Fuel Additives, when or not too add #6
I do the same as Looking4new. No problems with fuel.
/ Fuel Additives, when or not too add #7
I use both Stanadyne Performance and Lubricity year-round, with good results.
I use them even on the old CAV system on my 3930, as well as my (relatively) more modern 7.3L. I like how they designed it to de-emulsify tiny water particles.
Corrosion can create problems in any era of system, but the issue has gotten worse with more modern diesels. As fuel-rail pressure goes up, and injector geometry goes down, a tiny water particle that might just pass through an older mechanically injected system can end up blowing the tip out of an injector in a modern diesel.
Plenty of folks also have good results with Power Service (easy to find usually) and OptiLube XPD (harder to find). Injector pumps have always been spendy, and modern injectors have become non-low-cost too....
Water management matters a lot, and if you read up on the history of the back-room ULSD maneuvering, the engine manufacturers wanted a lower Wear-Scar limit that what Big Oil paid to have legislated. Adding legitimate lubrication to modern diesel fuel is wise, IMO.
Rgds, D.
/ Fuel Additives, when or not too add #8
DAVE nailed it.. I build injection pumps for a living & have seen it all, concerning NO additives in fuel systems.. I feel bad for folks that don't use it.. The older Roosa master/Stanadyne pumps & CAV's are grandfathered in and are the exception to the additive rule..
EVERYTHING ELSE should run a added lube in the fuel..
I'm replacing a pump housing this week because the rotating metal parts inside the pump literally ATE THRU the aluminum pump hsg..
The hsg. alone is 571.00 then the 10 miscellaneous parts that need to be replace & then the 500.00 labor to do it..
You have to weigh the pros & cons when using it.. can I afford to get the pump rebuilt/replaced every couple of years?? When does the cost of the additive become greater than the cost of a pump??
/ Fuel Additives, when or not too add #9
Ta 3930dave & thepumpguysc. I have to admit that, prior to my bio-contamination, I was very reluctant to put in a fuel additive. On the one hand, fuel production here in Aus is closely monitored to a strict standard; on the other hand, there are so many different "additives" promising wonderful results that it seemed like so much snake-oil being peddled.
I am grateful to the bloke who put me onto the "Fuel Doctors" product (they're a Queensland Co.) as it rescued my fuel system and gave me my tractor back. You are correct in the cost of a good product, though. For me, one litre of the "Fuel Doctors" cost A$38.00 from an autosupply store. A$165.00 for a 5 litre container.
It's worth paying though.
/ Fuel Additives, when or not too add #10
I do the same and never had a fuel issue of any kind. :)
/ Fuel Additives, when or not too add #11
There's also the cost of a tractor/vehicle being down when you need it, and being able to sleep well at night :yawn::zzz::zzz:....
Given the usual cross border split, that job you describe would be more (even currency adjusted) dollars up here. For laughs, I checked a 64oz bottle of Stanadyne on Amazon.ca and .com. Roughly USD $34 vs. Can. $180 ! That's how bad pricing is on some things up here.
The data is out there, and anybody that is new to diesels would be well served by talking a diesel mechanic out to dinner to pick his brains, or at least take a box of doughnuts in to the local injection system re-build shoppe.....
My CAV system is known as anvil-tough, but I still add the good stuff to it as well. I've used Stanadyne long enough to see how clean it keeps the fuel system - I'd continue to use it for that reason alone, but once I add in the anti-gelling, water management (reduces or eliminates risk of biological growth), and lubrication benefit, it's a no-brainer.....
I'm not interested in snake-oil though..... one of the reasons I initially went with Stanadyne is I figured from a business standpoint, they'd have to be insane to put out a line of useless products, given the volume of injection system components they sell into OEM markets.
"Ounce of Prevention....." is an old expression. I find that many people divide out into mostly 2 categories - ProActive or ReActive, when it comes to dealing with problems. That alone may determine how people view spending money on a good quality additive.
Rgds, D.
/ Fuel Additives, when or not too add #12
I have never used anything in my fuel and never had any problems. It doesn't get cold enough here to require an anti-gel agent and I keep my fuel inside an enclosed building so it limits any condensation buildup. My tank has been in use since 2009 and has never had a water, contamination or other issue with it. My RTV and B26 went 450 hours without changing the fuel filter. The B26 was beginning to have a lack of flow issue but the RTV filter was sparkling clean when I changed it. Both were fueled from the same tank and I cant explain the dirt in one and not the other but that is all that was in it, no water in either.
All my equipment is 2009 models and I have had no issue with fuel pump or injectors.
Mostly I think the additives are just for peace of mind for those using them and if that is what you need then definitely go for it. I would recommend anti-gel agents for those living where temps get below about 25F in winter if you plan to use your tractor during the cold weather.
As for lubricity issues, I have never heard of commercial equipment or farmers putting fuel supplements in their equipment and many of them run 10,000 plus hours without a fuel issue. For larger tractors burning upwards of 10 gallons of fuel per hour, that is a heck of a lot more fuel than any CUT owner will ever put thru his machine in a lifetime.
I will say that if you are running an older machine designed for use of high sulfur fuels, you may need a lubricity agent, but modern engines are designed to use ULSD and require nothing more than clean fuel.
For the diehard fuel additive users: I don't consider the statement " I have used xxx fuel additive since new and never had a problem" to be of much consequence since they likely could have done the same thing without using an additive. Lots of discussion on this and some scientific evidence that shows some of the additives to be worse than using nothing when it comes to scarring of the injection pump pistons. Google it and you will find tons of articles on fuel additives.
I see that I have a lot to learn concerning owning a diesel. I can also see the value and wealth in the lifetime of experience that many of you have, for that I am most grateful.
Rgds, D.
I too see the value in the old adage, but didn't want to damage or destroy the engine or any components by meaning to do well. Then in my ignorance end up like "THEPUMPGUYSC" stated and paying dearly. Another old adage is "ignorance is no exception to the law". I assume that covers the law of rule, physical law, moral law and of course mechanical law. Learning from our mistakes is as we all know a part of life.
But I want to thank you guy's for sharing your knowledge and experience in order to save some of us the expense and heartache of "Learning the hard way".....
Thank's again...
James
/ Fuel Additives, when or not too add #14
James, an ounce of prevention is worth a lot more than any walking in sub-zero temperatures.:D
/ Fuel Additives, when or not too add #15
While I don't think they'd hurt, the inline plunger style pumps on the Kubota are lubricated by engine oil. Pumps that will be bothered by the​ low lubricity are the stanadyne/roosamaster and CAV rotary style pumps.
/ Fuel Additives, when or not too add #16
Older article, but still relevant, and hopefully of interest to this thread....
Why Diesel Fuel Injectors Fail - Diesel Power Magazine
I do agree with Gary re. controlled testing is not easy to do. If a 10,000 hour tractor needs an IP at 7,000 hours, would it have made it to 12,000 with a good quality additive ? Hard to say, w/o starting off 12,000 hours of testing with 2 identical tractors (yes, I do know.... it would actually take more than 2 to come up with meaningful data :drink:) , aka way too expensive for a mere mortal like me.....
That link also cites the fuel Wear-Scar limits north/south of the 49'th..... they are different.
Rgds, D.
/ Fuel Additives, when or not too add #17
Thanks for verifying what I was told by a shop that replaced my pump and injectors for my truck a few months ago. Expensive to say the least.
On the way out the door I saw 50 cases of Stanadyne Lubrication fuel conditioner (If I recall the name correctly withought going and checking). I asked about it and this big injector and pump shop said that was the way to go because of lubrication needed from very dry fuel. I asked about Power Service White as a substitute as long as I had a few bottles laying around and he told me that does just the opposite of what is needed. It drys the fuel out even more.
Even though my tractors run without any additive, I put Standyne Lubrication to ward off any premature damage from very dry fuel.
/ Fuel Additives, when or not too add #18
I use the Diesel Formula STA-BIL Fuel Stabilizer regularly for the diesel tractor and the comparable product for the gasoline engines as the fuel sometimes sits around for a while between uses.
/ Fuel Additives, when or not too add #19
Ah yes, the world of elixers, potions, lotions, charms, amulets , crystal balls ,reading tarot
cards, rabbits feet and taking vitamins. Not to leave out fuel and oil additives .
Use #1 winter diesel in the winter instead of trying to keep #2 diesel from waxing the filters in winter. If there is water from condensation in the fuel, add IPA. That's it, that is all that is required ever.
/ Fuel Additives, when or not too add #20
i gave up on fuel additives. tried them. and tossed them.
1954 allis chalmers CA tractor. spits and sputters and will not run worth a darn. if anything is added.
1995 chevy blazer, never say any engine performance difference or MPG difference. always kept on general pre-maintenance, and maintenance on it.
ford 333c TLB added some non GEL to the diesel, due to older gas from summer. and it was a nasty winter with lots of snow. and wanted to make sure any starting issue was not result of diesel gelling up.
some of those additives. causes the fuel to take more compression, or harder to get to exploded / fire. and/or possibly creates more heat for more performance. non of which i really do not care about. i need less heat from fuel, a fuel that explodes / fires up easily. ya i am not right at max MPG / HP of tractor. but the handful of extra HP. i will never notice. on other hand, i will notice, extra pre-maintenance, and more so maintenance as in repair work, or when temperature gauge is more sporadic due to radiator is clogging up like usual.
don't get me wrong, there are places for the fuel additives. but used to fix something / clean something. not all the time.
granted i would imagine some folks here on forum, might have there own 100 to 500 gallon fuel tanks. and have fuel delivered. and might need something to deal with water, or bacteria growth at the tank.
i would imagine some folks (including myself), that let regular gas tractors and equipment set in winter. and need something to help keep the gas turning into varnish and causing issues with the fuel system.
i would imagine some of us have experienced bad fuel (from local gas stations), and causing some issues. and maybe needing a cleaning of the fuel system on equipment.
some folks might have bad place were equipment seats when not being used. and causes extra moisture to form in fuel tank.
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2019 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
SHOP FANS AND MIRRORS (A63569)
SHOP FANS AND...
Sundowner Rancher Express 20FT Livestock Trailer (A63118)
Sundowner Rancher...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
