Need a use for pickup bed liners
/ Need a use for pickup bed liners #1
cmyoung2
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
I have a couple of old pickup bed liners, trucks long gone, and never liked the liners anyway. But, they must be good for something. Any ideas on repurposing bed liners?
/ Need a use for pickup bed liners #2
They work alright as a snow sled behind an ATV/side by side. Cover for firewood. Cut into strips to protect ratchet straps from sharp edges. Rake leaves into them and drag into the woods with a lawn tractor/quad.
/ Need a use for pickup bed liners #3
Use with a load handler...even if you cut out the bottom to use by itself
/ Need a use for pickup bed liners #4
I like that suggestion. :thumbsup:
Possible/similar use as a storage container for driveway fill/sand/gravel?
/ Need a use for pickup bed liners #5
If you have a pickup cut them so they fit between the tailgate and the wheel wells (open end towards the tailgate). It creates a small bin to keep small stuff from sliding forward.
-R
/ Need a use for pickup bed liners #6
Every truck my dad, brother or I have gotten with a bed liner we pull around behind dads shop and take it out immediately. Can't stand them. I went by there the other day and dad had been cutting them into small pieces with the skil saw. He had a pile of pieces, lol.
/ Need a use for pickup bed liners #7
The guy that sprayed my bedliner often gets to take the plastic ones out in order to do the spray in bedliner. He will keep a few on display at the shop but at one time he was using them as covers for deer stands. They would make a nice cover for almost anything that is kind of small especially implements.
/ Need a use for pickup bed liners #8
I cut out the floor section and keep it. Recycle the rest, or toss it. Have a 4x8' and a 4x6.5' sitting outside the shop now.
Cut into ~10" strips, the ribbed floor sections make great snowmobile ski tracks so the carbides don't dig into the trailer floor. (Probably not much a need for that in NC...)
I'm planning to cut one up to line the expanded metal floor and sides of our little ATV trailer so stuff will slide out easier.
The other I'm turning into a sun shade for the tractor, mounted to the ROPS. :)
/ Need a use for pickup bed liners #9
I put my fork extenders on the FEL a ratchet strap to hold it to the frame and use it to sweep leave into on the ground or on the eave of the barn then I just take to burn pit and dump the leaves. also use it to pick up limbs and twigs after a storm then I just but it back in the equipment row till next time
/ Need a use for pickup bed liners #10
Are you going to put any type of insulation under it? That black plastic and the sun may make it hot underneath.
/ Need a use for pickup bed liners #11
Curious question... Why don't you like the plastic bed-liners?
/ Need a use for pickup bed liners #12
I don't like them because stuff slides to easily. I take them out and put a cheap rubber mat in.
/ Need a use for pickup bed liners #13
Agree with this....love my DualLiner branded one. Plastic on the sides and a rubber bottom. Customer service is 1st class too as the first rubber mat was cut odd and was too small. They sent me another one when I sent pictures. I threw it on top of the old one so mine is twice as thick.
-Joe
/ Need a use for pickup bed liners #14
Naw, it's far enough above my head that I doubt I'll get much radiant heat off it, but it'll block the direct sun, so an overall win, I'm sure. If it seems too hot, I'll just paint the top white. :)
A lot of good suggestions, may try implement shed, if I can keep it out of wife's sight. Should work good for my 2 wheel tractor implements. The rest of the ideas are good, but I don't rake/have leaves, don't have a ATV to pull as a sled(probably too old to think about that kind of fun), truck now has a flat, dump bed. Have used the tailgate pieces for skid plates. So Thanks for the input.
/ Need a use for pickup bed liners #16
I hate the plastic bed liners. Too slippery, ridges/grooves too deep for easy cleaning, cut down the volume capacity of your bed (yeah a nit), and who knows what is happening underneath over the years. I'm a fan of LineX and a slick mat to throw in when using a Loadmaster or other things that need sliding.
/ Need a use for pickup bed liners #17
I use one as a bin for brush removal on the steep slopes around my property. The slopes are way too steep to have a truck, tractor, or trailer on. I tied the tailgate portion to the the other three sides to create a 4 sided bin. Then I pull it by hand down to whatever part of the slope I am working on, fill it with brush, logs, etc. I have a rope that runs up to the tractor (no winch yet, but I have an old power winch waiting to be mounted), and I just pull the bin up the slope and drag it over to the burn pile. It slides easily on the grass and doesn't tear it up. It's the best way yet I've found to remove the multiflora rose, wisteria and grape from the steep slopes.
/ Need a use for pickup bed liners #18
reading through post... any stuff setting outside, that you might want to cover?
i refuse to put tarps over stuff anymore. wind will snag the tarps and tear the tarps to pieces, and end up wipping and making lots of racket. i would imagine plastic bed liner fairly light. tip it up side down and over something you leave outside. toss concrete block or something on top or if it has an edge. to keep it from blowing away.
do you need a spot for garbage cans? and keep empty cans from blowing away?
toss it on a 3pt hitch carry all. or onto some pallets, and use 3pt hitch forks.
toss it up on craigslist get a few bucks out of it and move on.
bolt them together to form 4 sides plus a top for a mini shed. then cut 1 or 2 doors into it, and toss on some hinges and a latch. going to assume you may need to "sandwhich" the 2 liners together, between some lumber or metal. to help form a more tight seal possibly.
have a generator that you been thinking of setting up for emergency outages? you got makings for a small little shed.
/ Need a use for pickup bed liners #19
Never did it myself but a guy suggested that we should smear a gallon or two of axle grease B4 installing a bedliner so as to prevent rusting.
Should work just fine.
