Land plane questions
/ Land plane questions #1
KanakaRick
Truckee, CA
KIoti DK50S
I spotted a used land plane for sale and I was curious if anyone knew anything about the Terrabond brand? It looks like the blades are fixed in a horizontal position (90 degreees toward the direction of travel), rather than an angled position (45 degrees off the direction of travel), does that make any difference? I would assume a person would want the blades angled towards the back so the gravel would flow backwards and fill better. Am I delusional, does it make a difference?
/ Land plane questions #2
Most have a much smaller angle, maybe 15 degrees. If you watch lots of them on Youtube, you will see almost no gravel movement sideways. I would actually prefer straight blades. I think angled blades are as much to lure buyers as to move gravel.
Here are some Terrabond graders, which appear to have angled blades.
TerraBond Spreader Grader - YouTube
Bruce
/ Land plane questions #3
Mine are fixed at 90* and I am pretty happy with the way it works. Ideally you want to cut deep enough so the blades cut at the bottom of the low spots. The blades run full of gravel all the way across the box and deposit an even layer over the fresh cut. If you don't cut to the bottom of the low spots they will still fill and the surface will look flat until you pack it. The low spots will pack more because the loose gravel is deeper there and you will need to grade again. Each time it will get better.
Like Bruce said = there seems to be little advantage to blades at a shallow angle.
gg
Doing a bit more research. My driveway is over a mile long, and the surface is ground up ashpalt from the local freeway, so the surface is pretty smooth to begin with, and isn't as tough to deal with as a rock or gravel driveway would be. Do you guys think a rake would be a better impliment to get instead of the grader scraper? I could use the rake for a lot more uses, if it would work as a alternative for the land plane. Thoughts?
/ Land plane questions #5
I would go with the tool that gives you the most bang for the buck first. With a mile long driveway you will undoubtedly end up with more than one implement anyway.
gg
/ Land plane questions #6
I would buy the landplane if you can get a good price. If you Google Terrabond, there is a video of them on Youtube. Why the landplane ???, long term it will take care of just about all you driveway problems. A rake has it's uses, but won't do much to fix a drive that is in bad shape. You need the landplanes length to plane off the high spots/low spots that develop.
/ Land plane questions #7
I maintain part of our road which is over a mile long. I couldn't do it well without a land plane. I used to use a box blade, rear blade, and landscape rake. Came out OK, but lots of fiddling. I still use those implements on the ditches, but for dressing the roadbed itself a few passes with the land plane followed buy the rake (at an angle and at speed to remove larger stones kicked up) and it is in perfect shape.
My grapple rake (front implement) and land plane are the two implements I have that I wish I'd purchased earlier and are worth every penny for my needs.
Guys, thanks for the advice. Land Plane it is.
Sorry about all the questions. I am getting my neighbors to chip in on the purchase. One neighbor has a skid steer, and I have the Kioti tractor. Is there any difference in finish between using a pull behind 3 point vs the front mount skid steer style? I can do both, but I recognize the front mount will be a dusty mother. If we get the drag behind, then it will be MY tractor doing the driveway, and if we get the front mount, then either of us can do it. Opinions please....
/ Land plane questions #10
I picked up this Bush Hog 60 inch land plane from my dealer who had it stashed in the weeds. I think it was $300, his cost. I put it on my little B series and it works wonders on my 1/2 mile gravel driveway to my cabin. Tilt up the front just a hair and it won't dig in... It even works good in soil if it isn't too wet, or dry.
/ Land plane questions #11
My machine is all front mount. Outside of the dust, which sucks, I am pessimistic that a landscape plane that works for a skid steer will work well for a tractor. It comes to geometry. to float a blade out front requires a different angle to push. While I cannot guarantee it, I would think you will be "Riding over top" of the blade a lot as your push point will be higher than the skid steer.
Good point.... the good news is on my driveway it is just asphalt grindings, so I don't know how much of a difference the elevation of the push point would make.... hmmm. I could see that in more difficult terrain, it could be a problem.
/ Land plane questions #13
Tractors pull, skid steers push.
The loader on a tractor is a bass ackwards implement. You need ballast on the other end, but the heavy engine is up front under the loader. The weak, complex & expensive axle is under the loader weight while the beefy simple axle isn't.
A skid steer having only 1 interface is balanced properly & has a MUCH beefier loader on comparable sized machines.
Don't plan on a SSQA interface on your tractor making it function nearly as well as a skid steer or being as tough when using the loader.
I love the SSQA in my loader, but it's still a loader, not a digger or pusher.
So in an ideal world, which vehicle is better for smoothing a road? We have a skid steer and a tractor- which implement shall we purchase- one for the skid steer or for the tractor?
/ Land plane questions #16
A tractor is designed for pulling. Dragging, smoothing & longer distances fall into this. A skid steer is designed for material moving, lifting & manuverability.
Skid steers impliments will cost more than tractor impliments in general. Impliments that are PTO powered are half the price of hydraulically powered stuff (rotary cutter, tiller, etc.)
A tractor will be faster by a lot generally driving it around & have a much better ride.
Cool, thanks. Personally, I very much dislike driving in the skid steer. I think the road visibility sucks and I can never get used to the fact that I just cannot see around me. Annoys the heck out of me. I will stick with tractor implements so I can see what is going on. Thanks for all the replies.
/ Land plane questions #18
While I do not have a skid steer, I do have a tractor with front mount implements. Fallon hit the points right on the head. That said, unless you are actively farming (Plowing, dragging, seeding) having your implements out front is fantastic. I would say for the vast majority of the gentleman farmers if they drove a front implement machine like mine they would convert. Just as and FYI,when I have to box blade or use a potato plow, I drive backwards. Not convenient but in reality almost everything I do on my farm has no ground engagement to speak of.
Thanks for the input Woodland. I could see for industrial uses, the tractor is best suited for dragging. But for light duty stuff, you may have a point. Do you have a forward mount land plane or box scraper?
/ Land plane questions #20
My box blade is front mounted, but I have to pull it (so drive in reverse). You cannot push a box blade very well with my machine.
I use a landscape rake for maintaining my road and I push it. It has wheels so it won't dig in too bad. What happens when you push and your tractor arms are floating if you build up too much material or you hit an imovable object your tractor tries to drive over the implement.
ATS Mini Excavator (A66285)
ATS Mini Excavator...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
20' One Trip Shipping Container (A66285)
20' One Trip...
