   / Share Pics of People Hauling or Towing Something Wrong #5,202
I just watched that last night, pretty cool.
   / Share Pics of People Hauling or Towing Something Wrong #5,203
   / Share Pics of People Hauling or Towing Something Wrong #5,204
The trailer for sure!
What would you say the trailer weights? It's a 3500lb axle, 3 bales estimated around 900lbs each, 2700lbs, leaves 800lbs for actual trailer weight.
Total was 3600lbs (estimated) of hay plus the weight of the PJ 6x12 trailer.
I personally think they were over 900lbs each, that load pushed me more and was harder to accelerate than this load IMG_7447.JPG which is a 2750lb trailer and 3 500-600lb (estimated) round bales, total of around 4500lbs. If it was more that trailer was way overloaded. Idk
That's the prob with hauling round bales, nobody ever knows what they weigh, can only guess. Those were 5x5 bales loosely packed on the single axle, 4x5 loosely packed on the double axle trailer.
   / Share Pics of People Hauling or Towing Something Wrong #5,205
I'm not sure this is "wrong" but it makes me nervous just looking at it. I will point out the tow vehicle is NOT a duly. IMG_0795.JPG
   / Share Pics of People Hauling or Towing Something Wrong #5,206
I personally think they were over 900lbs each, that load pushed me more and was harder to accelerate than this load View attachment 509097 which is a 2750lb trailer and 3 500-600lb (estimated) round bales, total of around 4500lbs. If it was more that trailer was way overloaded. Idk
Just a technical question. Assuming the tongue weight on the hitch was 300-500 lbs, shouldn't that be subtracted when considering trailer load limits?
   / Share Pics of People Hauling or Towing Something Wrong #5,207
Yes. You load front-heavy if you need to take a little extra weight off the trailer and put it on the truck.
   / Share Pics of People Hauling or Towing Something Wrong #5,208
I'm not sure this is "wrong" but it makes me nervous just looking at it. I will point out the tow vehicle is NOT a duly. View attachment 509098
The lack of dual rear wheels isn't much concern as the RV trailer doesn't exceed the tow capability/capacity of the truck (F250 SRW?), but I'm not sure about the lack of brakes on the boat trailer, hanging off the RV, hanging off the tow vehicle. Trailer sway could be a bear at higher speeds.
   / Share Pics of People Hauling or Towing Something Wrong #5,209
Honestly I am more concerned with the photographer taking pics as he is driving down the road......
   / Share Pics of People Hauling or Towing Something Wrong #5,210
At least his eyes are on the road and not checking or participating in some "critical" email thread.
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
METSO QUOTEC NORDTRACK S3.7 MOBILE SCREENER (A60429)
METSO QUOTEC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
