Talk to me about owning a Dump Truck
   / Talk to me about owning a Dump Truck
A little 4x4 Fuso would be awesome!! They're not easy to find with 4wd for reasonable prices though.
This thread has been really enjoyable, and full of good information. As I stated before, a dump trailer doesn't really fill my needs, but I have for now solved my dilemma...
I already own this flatbed, and was considering replacing it with a dump truck...
Instead, I'm converting it to dump, and adding drop sides and a two way tailgate...
I'll have to pay someone to haul in road base and gravel, but honestly, it'll probably cost me less in the long run than owning a capable dump truck (and maintaining it...) No CDL, no expensive registration, no DOT inspections, no unknown issues, and it's 4wd with low range. :)
It's not going to haul yards of gravel, but it'll work great around the property, and be fine for picking up smaller quantities of material. (Three gravel pits about 4 miles from our sub...)
   / Talk to me about owning a Dump Truck #34
Funny thing about owning a DT... you will all of a sudden find that you have good friends that you never knew before.
   / Talk to me about owning a Dump Truck #35
Dude, that little pickup flat bed is NICE! A good flat bed / stake truck is a perfect thing to have. I have two! Use them all the time, well, the F450 needs battery cables at the moment, but they are good to have.
You're correct about trying to find a 4x4 Fuso, VERY rare and hard to find. I got super lucky with mine. Only had 90K on the ticker when I bought it. Needed a little TLC, but it's been an extremely good rig, sips fuel and can take one **** of a beating... I just can't get any more than 3 or so ton in it before I can't pull 5th. Poor thing is begging for mercy, turbo is probably melting when I have it loaded up.... Good thing there are not a lot of hills at all around here.
Her she is in "tractor" mode. I'll just drive that fugly thing around my property and use it as a giant ugly tractor.
Thanks Maxfior!
When I worked for TRW, I tuned the traction control for the 2012's. (ABS/Traction/Stability control all from the same module, supplied by TRW.) I spent quite a bit of time driving them around. Our trucks all had the auto/manual trans, and I LOVED the way it worked!! Smooth shifting, and would "creep" when you released the brake, just like a normal auto. We never did get a 4x4, but I enjoyed pinning the pedal to the floor and cruising them around. The ones with the bigger engine were pretty quick, IIRC. Empty, that is... :)
Seems like a little FG Fuso would make an awesome plow truck too. I'm going to keep watching for a deal on an M1078... Quite a bit bigger than a Fuso, but probably quite a bit cheaper. More bang for the buck, so to speak. :)
I'm hopeful that my little dump bed will serve my needs well!
   / Talk to me about owning a Dump Truck #37
You can both think like that, but in simple terms, you're both wrong.
There is no problem registering for less than rated gvw. Registering for more than rated gvw is not so easy. If you register for 26k or under, no cdl needed, regardless of the factory tag. But then you have to stay under the registered weight.
Nope. You can register it for whatever you want but class of license required is determined by the manufacturers GVWR. Been down this road trying to get a 33k truck able to be driven by a non cdl driver.
I currently own a kenworth w900 tandem 54k dump and used to have an international 4300 non cdl dump. They are really handy when you need them but you will find you will quickly finish your projects and they will sit. I have used mine four days this year. When I first got it I used it daily. I am thinking of selling it. If I need one I can hire belly dumps for $75 an hour or even rent a belly dump trailer for a reasonable rate. Insurance and registration on my dump are over $2,500 a year combined.
   / Talk to me about owning a Dump Truck #38
Ya my boss thought owing a small dump truck be cool. "Ain't this great" he says. I said "What do we NEED a dump truck for...we need a flatbed stake body truck (maybe with lift) on the farm. Be more useful to us.
So this is how it goes...he gets a 450 Ford diesel dually dump used. The box was pretty massive and the tailgate wicked heavy, Would not swing out from the bottom because the latching/unlatchiing mechanism was frozen so it had to let down from the top. Something was out line so the gate also got stuck in the up position and you had to kick it or hammer on it to free it up enough to drop.
First he has some guy rattle can paint to cover up all the commercial markings that were on it
Now it really looks like crap its was dark blue but now its all black with no name
I get stopped by a cop because he don't like the way the truck looks :laughing:
Had a ring type pintle hitch we needed a 2 5/16 ball combo for my trailer. I had a heck of time removing the old one, no torch.
Boss put the Western plow from his 3/4 truck he junked for this...first winter he bangs the plow so hard because this truck is so heavy he cant remove the plow frame in the Spring. Took a second big truck our box truck and chain to get it apart...frame was so sprung that plow was junk.
Bought a brand new Fisher plow unit had it dealer mounted (probably cost more than the truck did)
Tailgate get stuck up so him and two amigos were banging on it in our business store front parking lot to open it... FELL RIGHT OFF THE BOTTOM HINGES and crashed to the ground snapping the upper chains, luckily nobody got hurt.
That got the bottom hinges welded shut for good :shocked:
Box wouldn't raise for him when he got it...I found it low on fluid
Twice on me the box got stuck in the up position last year. Total lack of prior maintenance hadn't been greased in years I got it down after some time using some tricks but after this winter the boss was out of town with it 30 mi away at another farm we own and it got stuck up again on him he just left it there a week later brought another truck and chain and forced it down.
Wanted me to deliver wet bark mulch in the rain so drove it off road in wet weather and got stuck...even with 4wd because of all the weight. Had to dump the load where I was to get free.
Truck is gone now he had an upper exhaust leak and the oil pan had a hole in it garage quoted him a lot of money and something about removing the engine :eek:
I don't really miss the truck only miss towing any of the tractors we have with it. Now we have to drive the tractors between farms or hire a carryall.
Ha here was one of more fun jobs...boss bought this restored hay wagon on a whim I had to go pick it up a 150mi round trip (boy did my back ache riding all that way in that truck)
So got to trailer a trailer on a trailer with that old truck ;)
   / Talk to me about owning a Dump Truck #39
Mine was slowly becoming a money pit and it was one piece of machinery I regretted buying. I had about 8 miles to the quarry and that thing
would beat me to death. I would get maybe three loads hauled and I was done. The local quarry was closed on weekends but the owner
said it was ok to load yourself, which takes time. One time I got there only to find out their loader wouldn't start so a wasted trip. Then I had to
weigh and fill out the ticket and weigh empty when returning. So after maybe three years I put it on CL and had some kid from 700 miles away
buy it. He wanted to drive it back and I said your crazy. He took it to an area motel where they could leave it for a week and have a buddy come
and haul it with a semi. I was doing a happy dance when I had cash in hand and that thing was leaving my property. :)
My little dump-pickup is still rocking!
We used it a LOT to haul material (pretty much busted up and slightly damp clay) from the barn site down the drive for fill on the low side. I can get 5 heaping buckets of material on it before I start feeling bad that I'm overloading it... I have a 72" "HD" bucket, which is probably about half a yard. So 2 to 2-1/2 yards a trip... We also shuttled a lot of material from the back of the barn site to the front, where the fill will become my parking/turnaround area. Faster to load the dump and move it 150' 2+ yards at a time than to drive the tractor back and forth over and over and over... I bet we've moved easily 200 yards of material...
To make its life easier when we're working on the property, I pull the "4wd" fuse, then toss it in low range. Since it's an old school floor shift t-case, pulling the fuse just keeps the CAD from engaging the front, giving me 2-low. Works great for maneuvering around the property without all the binding from 4wd. Actually works well enough that I'm planing to add a switch on the dash when I get a chance...
It also gets to haul cold patch from Aztec NM up to Mancos CO occasionally as we fix up the entry road to our community. So far I've only picked up a couple 2k lb loads, but next trip will be 3k, since we'll be dumping and spreading, rather than shoveling it out by hand to fill potholes. Gonna have to figure out how to chain the tailgate so it doesn't just dump in one spot...
Had 120 yards of road base for the driveway hauled in by big truck a few weeks ago. About $100/load deliver charge, so $1k for delivery and ~$1200 of material. Now that I've got it fairly well groomed, it's a little thin out by the road. Rather than pay another $100 for a truck to deliver more, I'll just trip to the quarry at lunch a few times next week. Two or three lunches and it'll be fine. I'll probably pay for delivery when we gravel the 200' drive out tho the pole barn, but I suppose I could just make a trip a day for a few weeks if I wanted... It's 7 miles from my place to the quarry...
Since this was only a 3/4 ton truck, I did add a leaf to the pack. I had two #2 leaves left over from some spring work on my duramax a few years ago. Cut them a couple inches shorter, added holes for the slider pads, and slipped them inbetween the original #2 and #3 leaves with some new center and U-bolts. That seems to have done the trick, and it doesn't look so overloaded now, (even when it is...). :)
I did finally pile enough wet clay (out of a ditch that I was cleaning for the HOA) on it that it wouldn't dump backed up our drive, but my driver (wife) said she just spun around and it dumped fine with the front of the truck pointing slightly uphill. I think the hydraulics max out at about 6k lb... So that might have been a bit overloaded.
The drop sides are awesome for loading stuff, like the post hole auger and hydraulic skid steer attachment that I just rented, or pallets, or whatever...
No regrets as of yet, other than not taking any pictures of the work with my camera. I'll have to steal some from my wife. :)
Oh, and guess what showed up on CL the other day... A nice '86 GMC 4 yard dump for sale for $4k. Tempting, but I think I'll just keep my baby dump. :)
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
