Kubota U25 Mini Bucket Question
/ Kubota U25 Mini Bucket Question #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
I just bought my first Mini excavator which is a u25 Kubota. I am new to Mini and dont know much about them in general. My hoe (purchased used) came with 2 digging bucket. In the past I have seen adapters on other machines that convert a digging bucket into a smooth or clean out type. What are those called and where can one purchase?
I am not sure if I just need to buy a clean out bucket, or if I can just buy these bars that go over the teeth?
Any advice?
Thank you.
/ Kubota U25 Mini Bucket Question #2
You could weld some flat stock over the teeth. I've seen some do that. Buckets are fairly cheap new, take a look on ebay. There is also a company called AIM Attachments (do a google) if you deal with them direct (call them) you can often get a better deal. They gave me a good price on a 18" bucket for my U35.
That is what I needed up doing. I had a piece of 1/2" welded to the 2 outer teeth. That way I can pop the pins and remove it. They made it about 3" wider than the bucket and it works pretty darn good. I will check out AIM Attachments- thanks.
BTW- how do the teeth come off? do you Pound the pins up or down?
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2022 EZ-GO ELITE...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
Unverferth RHD1645DG-36 Rolling Rarrow (A63116)
Unverferth...
