Mini-Skid Steers - Are they good or bad?
   / Mini-Skid Steers - Are they good or bad? #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
Lately I have been looking at Mini Skid steers to be bridge some gaps that I have between my Kubota BX25 tractor and Excavator. I have never operated one, and would like to hear from those that have to see if they are work pursing.
   / Mini-Skid Steers - Are they good or bad? #2
what are you doing? as in...
--getting down into a basement / crawl space?
--having to deal with narrow width gate?
--drive through home to get to the back yard?
--smaller acreage 1 to 2 acres. and wanting to do some landscaping with smaller size concrete blocks to timbers and smaller size rocks?, (what ever helps to remove shovel from hand)?
Basically everything you have a said there. I need something that can go up and down steep slopes to carry wall block and haul material. I also like all the attachments ( harley rake, trencher, auger ect.)
It seems like these are easy machines to use, and have quite the capacity for their size. I imaging that if you were on the thing all day just standing an moving material that would be become fatiguing, but if you need to do a lot of jumping on and off I imagine they are great.
Looking for general positives and negatives about them.
   / Mini-Skid Steers - Are they good or bad? #4
With most of the minis, if you are on steep ground, you need a good seat belt, hard hat and roll cage. This is even if you carry loads low.
Norm- Sorry, I was referring to the stand on type. Like a Toro Dingo.
   / Mini-Skid Steers - Are they good or bad? #6
Those (Dingos) are a bit more stable because they don't have to have a place inside for an operator. I've seen more than one person do a face plant with the small Bob Cat with the single cylinder, I think a 10HP engine. They were used mostly for cleaning stalls etc. but they would go through a doorway and were handy within their limitations.
   / Mini-Skid Steers - Are they good or bad? #7
I know they're cool as heck and I want one. Based on what I've seen they're stronger than the loaders on a sub compact tractor.
   / Mini-Skid Steers - Are they good or bad? #8
They can be very unstable in difficult terrain. I would say, most non-tracked skid steers are out of their element in steep terrain. Varying makes carry their loads much different from the next one. I for one, hate getting in and out of one. The exception being the ROBOT by JCB with the side entry.
   / Mini-Skid Steers - Are they good or bad? #9
For those that have never seen a TORO Dingo:
   / Mini-Skid Steers - Are they good or bad? #10
I've seen several tree services that use dingos or the one that Vermeer makes. They seem super handy, and having worked for a few tree services (none with a dingo, though) I can say that if it'll stand up to that kind of work, they must be a pretty solid machine.
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2025 SDLanch IRLMB Concrete Mixer Skid Steer Attachment (A56860)
2025 SDLanch IRLMB...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
208316 (A58375)
208316 (A58375)
2019Grove 9000-2 115T Crane (A60460)
2019Grove 9000-2...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
