Mini-Skid Steers - Are they good or bad?
   / Mini-Skid Steers - Are they good or bad? #1
flienlow
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
Lately I have been looking at Mini Skid steers to be bridge some gaps that I have between my Kubota BX25 tractor and Excavator. I have never operated one, and would like to hear from those that have to see if they are work pursing.
   / Mini-Skid Steers - Are they good or bad? #2
what are you doing? as in...
--getting down into a basement / crawl space?
--having to deal with narrow width gate?
--drive through home to get to the back yard?
--smaller acreage 1 to 2 acres. and wanting to do some landscaping with smaller size concrete blocks to timbers and smaller size rocks?, (what ever helps to remove shovel from hand)?
Basically everything you have a said there. I need something that can go up and down steep slopes to carry wall block and haul material. I also like all the attachments ( harley rake, trencher, auger ect.)
It seems like these are easy machines to use, and have quite the capacity for their size. I imaging that if you were on the thing all day just standing an moving material that would be become fatiguing, but if you need to do a lot of jumping on and off I imagine they are great.
Looking for general positives and negatives about them.
   / Mini-Skid Steers - Are they good or bad? #4
With most of the minis, if you are on steep ground, you need a good seat belt, hard hat and roll cage. This is even if you carry loads low.
Norm- Sorry, I was referring to the stand on type. Like a Toro Dingo.
   / Mini-Skid Steers - Are they good or bad? #6
Those (Dingos) are a bit more stable because they don't have to have a place inside for an operator. I've seen more than one person do a face plant with the small Bob Cat with the single cylinder, I think a 10HP engine. They were used mostly for cleaning stalls etc. but they would go through a doorway and were handy within their limitations.
   / Mini-Skid Steers - Are they good or bad? #7
I know they're cool as heck and I want one. Based on what I've seen they're stronger than the loaders on a sub compact tractor.
   / Mini-Skid Steers - Are they good or bad? #8
They can be very unstable in difficult terrain. I would say, most non-tracked skid steers are out of their element in steep terrain. Varying makes carry their loads much different from the next one. I for one, hate getting in and out of one. The exception being the ROBOT by JCB with the side entry.
   / Mini-Skid Steers - Are they good or bad? #9
For those that have never seen a TORO Dingo:
   / Mini-Skid Steers - Are they good or bad? #10
I've seen several tree services that use dingos or the one that Vermeer makes. They seem super handy, and having worked for a few tree services (none with a dingo, though) I can say that if it'll stand up to that kind of work, they must be a pretty solid machine.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
TANK MANIFOLD (A55745)
