John Deere Z445 2008 drive extension spring diagram needed, wont pull incline
   / John Deere Z445 2008 drive extension spring diagram needed, wont pull incline #1
Tom9258
De Soto
Z445
I have a Z445 2008. I am needing a copy of the diagram which will specify where the drive extension spring attaches. Also having trouble with the hydraulic arms. When in motion and on incline has a tendency to sputter when making this maneuver and also in turning with the arms. Any help would be appreciated. Thanks! Tom
Thanks for your reply. Yes I have the operators manual. Service Transmission
But it isn't clear as to where the spring attachs on the left side of the pic. There really aren't too many options to attach it to. I had asked at the dealers, but they were not wanting to comply with the knowledge. hmmm.
Tom
   / John Deere Z445 2008 drive extension spring diagram needed, wont pull incline #5
Tom,
I do not own a Z445 nor do I have any user knowledge of it, I just thought that the user manual may help.
Good luck,
Richard
   / John Deere Z445 2008 drive extension spring diagram needed, wont pull incline #6
I also have a Z445 2008 bought in July. I a having a TERRIBLE time finding a diagram or advice on how to access/remove the carburator - specifically removing the air filter "bracket" that sits over the carb. Its Labor day, small town everything is closed. I realize this is an old post, but its worth a try. Than you.
   / John Deere Z445 2008 drive extension spring diagram needed, wont pull incline #7
Welcome to TBN 📣
Does your Z445 have this engine: Kawasaki FH721 ?
If not, what engine does it have ?
Richard
   / John Deere Z445 2008 drive extension spring diagram needed, wont pull incline #8
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2-FLOOR JACKS (A55745)
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
