Magnetic Ground Clamp
/ Magnetic Ground Clamp #2
With a magnetic clamp you still need to make a good low resistance electrical contact with the metal below, so paint or thick rust would need to be removed first. You may get away with using it over light rust, though I would take the extra few seconds to clean the surface with a wire brush and be sure.
The one I use has a little lever that can be turned to reduce the magnetic force to almost zero. That makes it easier to remove. It also greatly simplifies the task of cleaning accumulated magnetic "filings" that inevitably accumulate when grinding. They cost a little more, but I think they are worth the extra money.
/ Magnetic Ground Clamp #3
I like mine. Nice for those projects that don't have an area close to your weld where a traditional jaw clamp will work.
Terry
/ Magnetic Ground Clamp #4
Needs clean metal for the electric contact. Magnet works over rust or paint. Electric contact usually right in the middle of the magnet like a bullseye.
Ah-shucks, I was hoping for a shortcut for one less spot to clean up and repaint.
/ Magnetic Ground Clamp #6
I would suggest one like Big Barn shows. Great for larger pipe and hard to reach places. I used to sell these things and the bigger the better and you get what you pay for although most of these are over priced. You will still need a regular ground for non ferrous of course.
/ Magnetic Ground Clamp #7
I've had mine three or four years now. My LWS(s) didn't even have them on the shelf. They wanted to order one in for me.
I "ordered " it myself from Amazon. Cheaper too.
/ Magnetic Ground Clamp #8
I've got a cheap one. Fills up with grinding dust quickly. Not strong enough for rusty/painted. Copper lined the jaws of some clamps and ran cable to it for my little mig. Nice to be able to hold little stuff well with just the ground clamp.
/ Magnetic Ground Clamp #9
Amazon link?
/ Magnetic Ground Clamp #11
Here's an Amazon link but better shop around. I'm certain I paid less, but several years ago.
Magswitch Ground Clamp 3AMP Magswitch 3 amp On/Off Magnetic Ground - Welding Clamps - Amazon.com
Thanks Terry... although a cool toy, I am not sure I can justify it but it WILL go on my xmas list. :D I can see for certain situations (heavy equipment) finding something nearby to clamp to might be an issue. I'm a hack and probably shouldn't be in those situations anyways :laughing:
/ Magnetic Ground Clamp #12
One can certainly get by forever without one but....
Quite often I need to tack up an "assembly" that can't be held tightly in place with clamps. Just carefully attaching the jaws of a traditional ground clamp may knock everything out of position.
The Magswitch however can usually be attached without disruption.
Plus as yomax4 mentioned, it's great for large pipe, large flat surfaces AND my 3" thick steel welding table top.
Terry
/ Magnetic Ground Clamp #13
Definitely see applications. Surprised after going through some of the reviews... seems the magnet isn't all that strong. Which can be a good thing from my understanding (not personal experience) of welding near magnetic fields.
/ Magnetic Ground Clamp #14
Mark, here's a little better price (looks like they may have changed the design, left out the smooth outer cover tho)
Magswitch Magnetic Ground Clamp - 300 amp 8100746
I've found that any grinding dust/filings come off just about ANY magnet by blowing it off with high pressure air; a quick back and forth movement seems to work best. The air gets the "stickies" far enough away from the magnet (even a NON-switchable one) not to return... Steve
Just be SURE to have leather gloves on, and not too close to skin - AIR EMBOLISMS CAN BE FATAL...
/ Magnetic Ground Clamp #16
/ Magnetic Ground Clamp #17
I just checked out those reviews, Mark and found the one regarding the weight of the cable pulling the magnet off the workpiece questionable.
I just bundled up 20 pounds of welding lead to see how it would fare.
Magnet held the weight without problem and I didn't see the point in ADDING more weight to see when it would fail.
Even if one was up a fifty foot pole I'm certain they could loop the lead over something to alleviate the weight/strain on the Magswitch ground.
* I realize this may have been more appropriately posted in the "Get a Life" forum.
Terry
/ Magnetic Ground Clamp #18
/ Magnetic Ground Clamp #19
just ordered this ty, looks to be awesome for pipe.....
/ Magnetic Ground Clamp #20
Nice price but once you see the advantage of a "switchable" magnet not "pulling " apart a delicate assembly when attaching you'll never go back.
Oh I can see the advantage of a switchable magnet for small things alright. But if you are welding on a big slab of metal the Radnor type does just fine. It is a two handed job to get off sometimes so there is no question that it will hold quite a bit of weight if the ground cable is suspended from the magnet clamp.
1993 Ford F-150 Ext. Cab Pickup Truck (A61573)
1993 Ford F-150...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
4' 3pt Dirt Scoop (A64119)
4' 3pt Dirt Scoop...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65579)
IMPORTANT PLEASE...
26ft Mobile Spray Foam Trailer (A61573)
26ft Mobile Spray...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
