May 2, 2017 / 4310 fault code help??? #1 N NBC455 New member Joined May 2, 2017 Messages 3 Location Murrieta Tractor 4310 I have 1 fast, 5 fast, 1 long.. Any help greatly appreciated.
May 2, 2017 / 4310 fault code help??? #2 kennyd Advertiser Joined Jul 6, 2003 Messages 13,837 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 Look here: Attachments 4X10 HST Codes.pdf 31.3 KB · Views: 301
May 2, 2017 / 4310 fault code help??? Thread Starter #3 OP N NBC455 New member Joined May 2, 2017 Messages 3 Location Murrieta Tractor 4310 Thanks for that. The flashes I get are a total of 7 and I can't seem to find that anywhere. I get a quick flash, then a second goes by, then 5 quick flashes, then a second goes by then a long flash. Goes off for 3-4 seconds and starts over... BTW, 4310 12/12 Reverser
May 2, 2017 / 4310 fault code help??? #4 kennyd Advertiser Joined Jul 6, 2003 Messages 13,837 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 NBC455 said: BTW, 4310 12/12 Reverser Click to expand... Well the devil is in the details, you did not mention that so I assumed HST and posted the codes for that. Try these... Attachments 4X10 EPR Codes.pdf 31.6 KB · Views: 250
May 2, 2017 / 4310 fault code help??? Thread Starter #5 OP N NBC455 New member Joined May 2, 2017 Messages 3 Location Murrieta Tractor 4310 Thanks for these. I'll give it a try from the suggestions. kennyd said: Well the devil is in the details, you did not mention that so I assumed HST and posted the codes for that. Try these... Click to expand...
