   / Harbor Freight Tools that don't suck #7,321
Anybody try one of these.Not bad for the money.High Lift Riding Lawn Mower / ATV Lift
   / Harbor Freight Tools that don't suck #7,322
2 cents here; bought a needle scaler to remove slag from sub frame welds for my fabricated back hoe, 1.5 hours both ways to China Freight...I pre oiled it, set my reg. to 90 and had a joyous 4 minutes of exemplary performance. Moral...it looks like what you wanted, but don't count on it.
   / Harbor Freight Tools that don't suck #7,323
   / Harbor Freight Tools that don't suck #7,324
I haven't tried one mostly because I just use the FEL on the tractor to lift the mower. It's cheaper to buy or repurpose a couple of 2x4s as safety blocks to hold up the loader while working on the mower. Also easier to store.
I do the same after a wise tip here on TBN some time ago. Could've been you, IT.
   / Harbor Freight Tools that don't suck #7,325
How funny, I have one that's been lubricated twice, has more than a few hours on it and has worked very well on my compressor which is set at around 120 PSI.
Aaron Z
   / Harbor Freight Tools that don't suck #7,327
That or preferably the loader are sure better than what I tried, the HiLift jack, when I wanted to pressure-wash under the Rotary Mower before I installed it in the spring. HiLift jacks are treacherous. Sure enough it came crashing down. I'm cautious when using it, no harm done, but that confirmed my opinion of them.
I got the HiLift (used) way back when it was reasonable to solve hi-centering my Willys Wagon by jacking up the front or back (simple steel bumpers) then letting the jack fall sideways to drop the Willys away from the ruts it was in. I've only used it a few times since, with much caution. I doubt HF's clone version ('Farm Jack') is any safer. Not Recommended unless you have a specific need that only this will solve.
   / Harbor Freight Tools that don't suck #7,328
... needle scaler to remove slag from sub frame welds for my fabricated back hoe,...[lasted] a joyous 4 minutes ...it looks like what you wanted, but don't count on it.
Mine was ideal for the specific project I bought it for: Grout around the plastic pipe into the septic tank was crumbling and leaky. Those long pins were the only tool that could get into the tiny gap between the pipe and the concrete tank wall, and clean out the joint so I could re-cement it. That worked great, re-grouting sealed it perfectly.
However ... My HF '2.5hp' 10 gallon compressor was rated about the same air volume as the needle scaler but somebody was dreaming. Using the tool exhausted the compressor tank in a few seconds. This was one of those cases where you buy the HF tool for a specific project and it pays for itself the first time you use it but the tool (in this case run from the 'matched' compressor) was hardly worth using again. Next time I got it out a year or so later it took some serious hammering to free up the stuck piston despite having run oil through it after the previous use. After using it that second time and again cussing the compressor, I haven't used it since.
Has anyone tried the mini needle scaler?
   / Harbor Freight Tools that don't suck #7,330
My scaler must have come over on the same boat! Lasted about the same amount of time.
2016 Hyundai Sonata Hybrid Passenger Car, VIN # KMHE24L18GA041858 (A57453)
2016 Hyundai...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
ALLISON TRANSMISSION (A55745)
ALLISON...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59575)
2017 ISUZU NPR 18...
