Post frame shed?
/ Post frame shed? #1
petebert
Outside of Ann Arbor
I want to get a shed. Park the riding mower in it and get all the kids stuff out of the garage, bikes, sports gear etc.. So I started looking at all the shed options at Menards, lets say somewhere around 10x10 in size. I don't plan on pouring concrete so I'd have to figure out how to anchor most of the sheds. Don't care for the idea of a shed floor much. It will rot over time and create a great rodent habitat, plus I would need a ramp to get the mower in. So now I'm thinking, why not do a post frame shed with a dirt floor? Menards has premade 12' shed trusses for around $50. Sounds pretty simple to me, just sink some 4x4s in the corners and go with metal siding. Essentially a very small pole barn.
/ Post frame shed? #2
Pole barn buildings are the most cost effective and simplest of all buildings to create.
/ Post frame shed? #3
I agree with Eddie. If you want a dirt or gravel floor, pole building is the way to go. Even though it is a small shed, I would still likely use 6x6 posts, rated for buried ground contact. It may change based on location, but in NY with clay soils I dug a hole to below frost depth, about 16" in diameter. I then used the hand held post hole digger to make the bottom of the hole a bit wider. Then I put some gravel in the hole, tamped well. Then concrete in the hole to create a concrete cookie to set the post on. We had very heavy clay soils, so instead of encasing the pole in concrete, I set the post on the cured concrete cookie, leveled the post, then backfilled with the heavy clay and tamped it extremely well (this is very tiring work). I did that all the way to to top, and then 4-6" above to avoid water staying near the pole after a rain. The structure was extremely solid.
-Joe
/ Post frame shed? #4
-Joe
I am still amazed at how old some of the old time pole sheds last and how useful and well they work. One thing I want to research is how to provide some degree of moisture barrier beneath the dirt or gravel. First thing of course would be to elevate the floor to provide good drainage all around perimeter. But would some plastic under the gravel help ward off the inevitable moisture soak for things piled on the floor, or if not would it slow the process down. Gravel would just punch it full of holes, but maybe slow moisture down enough to be beneficial, - or is there a kind of membrane that would work under about 4 or 5 inches of gravel with daily traffic
My sons are picking up on the build what you need that you can afford idea. Hoping to guide them into building their cheap building in a way that stands solid long after I am gone. My grand father taught me the art of tamping wax clay around the poles. But dirt floors were just dirt floors😀 Built on whatever slope there was.
/ Post frame shed? #5
Keeping the building drafty is how you'll keep the moisture from the ground controlled. Lots of the hundred-plus year old barns have existed as long as they have by having steady airflow to keep things dry inside. Don't seal the walls with large panels that don't breathe. Old timers used 10-16" wide boards with small gaps between. Leave a small gap around the bottom for air also. Venting the roof is good to let heat out too.
/ Post frame shed? #6
-Joe
Good advice here except I would backfill the holes with gravel (3/8 to 1" because it compacts well) instead of clay. This will keep the post much drier. For the size of shed you are looking at, 4x4 provides plenty of strength. Sometimes they warp more than larger posts, which is the concern but I have found them to be OK. A compromise is 4x6. My 40 x 48 pole has 4x6 on 8 foot centers and it's fine after many years. Before you build make sure you check local codes. Most places in Michigan are under code and they usually allow a certain size building without a permit. In my township it is 120 square feet. I would always suggest building exactly the largest shed you can without a permit.
/ Post frame shed?
I'm in a ag zone, if it's an ag building no permits are required. I do want to continue the roof beyond the building to provide a summer shade shelter for sheep, that makes it an ag building right?
Most of our soil is pretty sandy. I just had a 6-7' hole dug the other day and it was sand all the way down. There is clay on some parts of the property, near the barn I found clay 3-4' down. I'd probably do 4' holes with premade footings dropped into the hole. Gravel would be a good idea, would stay solid beyond my lifetime I'd think.
/ Post frame shed? #8
Yeah, simple small pole barn is a great idea. But make it bigger! No sense going to that much trouble for a 10x10.
/ Post frame shed? #9
bring in dirt if you have to. to raise the shed up in the area so water will run away from it.
make sure gutters get put on and run that water away from shed as well.
run a couple 2x8's or something from dirt level on up. maybe a few more boards higher (depends on sheep) animals love kicking and scratching. and will bend/twist/wreck metal siding. also the boards act as a "tractor FEL" stop. so when ya cleaning out the pig pen of poo and piss. you have something to possibly hit. and you will hit the side.
with the metal siding starting up above the 2x8's. it keeps the metal siding in better shape and good condition longer.
tongue and grove 2x8's or 2x6's. might be consider for boards on the sides. and just giving a little spacing when hanging them up. the tongue poking up into the grove. still allows some air to flow through, causes water to run off the tops, and allows for some expansion/contraction of the boards. by the lumber cheap. and get a router and put the tongue/groves in yourself if you think it is worth going to that trouble.
/ Post frame shed? #10
In my experience, it's too great a gamble buying treated 4x4's for anything taller then a porch railing. Even then, it's iffy. I've seen 4x6's bend like a bow, but not as often as 4x4's. For me and what I do for clients, I will only use 6x6's.
I don't understand how gravel keeps moisture out of a hole? Seems to me that it would hold water longer, and it would also provide a void for moisture in the surrounding soil to travel to. If your soil is good clay, then it's fine for back filling. If not, spend the money on concrete.
/ Post frame shed? #11
If the underlying soil lets water drain, then posts in gravel will be drier. I have seen in some parts of the country that they now recommend backfilling post holes with self-compacting gravel for this reason. However, if your soil is clay like mine, it won't help one bit -- that clay post hole is going to be like a bucket. Probably make things worse!
The other consideration is wind load -- when we did my barn, the building inspector asked for a soil/footing analysis, and that told us the post holes needed to be backfilled with dry mix concrete and not the dirt/spoils. Because of my soil type, the spoils -- even if compacted -- would not have been capable of resisting much side wind load on the posts.
/ Post frame shed? #12
I guess local conditions impact the optimum approach. A post hole dug here will be dry and stay dry which is why I like gravel. The only place I've ever had water in a hole I dug is in my pond dam. For a large building you do need to consider side loading, but for a storage shed I doubt it makes any difference.
/ Post frame shed? #13
One of the first things I built when I bought my acreage six years ago: A pole barn above my shooting bench, to keep the sun and rain off my head. Works as good today as the day I finished, and requires just about zero upkeep. I made the trusses from 2x4s. I don't think I spent more than $300 on the structure, including the roof.
/ Post frame shed? #14
Buy the bury in hole concrete short post, that then bolts to the 6x6. No moisture on post to worry about. Additional expense, but post is kept dry. Back fill with tamped down material of your choice.
/ Post frame shed? #15
Hummm "bury in concrete short post" are you speaking of a short 6x6" that could be made by cutting up a longer 6x6? or is this something else?
commenting on the backfill method used, if you soil is clay and doesn't drain you certainly do not want to backfill with gravel. it will rot in a few years at best. the post does not have to be kept dry in the hole, you just need to deny access to oxygen. That is why the ole timers around clay country here always said, tamp until it makes your steel tamper ring everywhere around the post. My barn was built in the late 1800's, cedar posts in clay. One perimeter post where I carelessly scooped the dirt mound away from the post delighted me with how solid it looked but then rotted out in about 10 years because water could stand in the depression I left for several days after a rain. On another location in the barn, the ground stays wet due to slow drainage but the poles there are still solid. The clay is stilled bermed up around those posts from the original install I guess. Anyway wet in the ground is not what you are trying to avoid. Wet where it can get oxygen is what you want to avoid. I had to experience poor draining soil to catch on. The farm I grew up on, you could fill a hole with water and in a very few hours at most it would be dry. On my current place you can fill it and watch it empty at the evaporation rate for days and weeks. So septic systems are mostly of the lagoon variety in new construction around this part of KY.
/ Post frame shed? #16
You live in Michigan....so I don't need to Tell You about Lake Effect.....I'd just make sure I had a steep enough roof, to shed that lil' bit...lol..of Snow you get.
/ Post frame shed? #17
Pole barns rely on well tamped posts for structural strength and to hold it in place during wind storms. I wouldn't use gravel or crushed stone, but we'll tamped soil instead.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
Hay Rake (A65640)
Hay Rake (A65640)
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
