Yammer 2210D
/ Yammer 2210D #3
Testing compression on these is so difficult that I would find some other way to determine whatever it is you want to measure.
What do you observe, that raises this question?
/ Yammer 2210D #4
Can you say a little more, California? I have been experiencing (what I think is) above-average blow-by from the crankcase vent on my 155D and was planning to check compression soon. But maybe not the best course of action?
Hopefully not hijacking the thread OP :D
/ Yammer 2210D #5
I bought new injectors, and had such a difficult time getting original injectors out that I felt they weren't worth saving for re-use.
See my old longwinded post where I essentially cussed each step of the job. I expect your experience would be identical.
If it really needs valve guide seals or new rings, then I would just start on that. But if it were mine I would just live with it until the blowby was unbearable, or it became hard to start. It might take years to get any worse, I could live with that.
/ Yammer 2210D #7
Thanks guys. CA great documentation in that post! Excellent way to scare a neophyte shade-tree wrencher like me away from even trying ;-) Winston, I saw that video last week after I started my research in the wonderful TBN archive. I would say that, after 1.5 hours hard mowing last week it was indeed at that level. But it starts easily -- once I put cetane in it's been amazing -- and it doesn't smoke start to finish that I can tell.
I'm wondering -- now that I've thoroughly hijacked the thread -- is there a relationship between overheating and blowby? Could it be blowing more because the engine is too hot? A post from a few years ago the guy was thinking he needed to muriatic acid flush his rad core and that would help. I still haven't fixed my engine temp light. Stupid, I know.
/ Yammer 2210D #8
I suppose there could be a small relationship between overheating and blowby but very small. I was probably the one you read about with the muriatic acid flush. I did do that successfully. Same radiator was on the tractor when I sold it several years later. If you have reason to think you are running hot you need to get that fixed. Overheating is a head gasket killer on these little engines.
/ Yammer 2210D #11
Did you have the same issues CA did he replaced his injectors or did it go pretty smooth..??
td
/ Yammer 2210D #12
I removed both injectors on my 2210d with out any problems. Mine were leaking. They came out pretty easy, or I just got lucky one of the two. But Hoye does sell this injector remover tool as well INJECTOR REMOVER KIT: Yanmar Tractor Parts
Despite what others said, I didn't want to pay the price for a new injector so I took mine completely apart and put new guts in them for way less money and have zero problems. I did soak the top of the head around the injector with diesel fuel to break down any build up around the injector and it came out easily.
/ Yammer 2210D #14
Lol California!! I think the same thing about you and several other members on here. But that is what I did & I am very happy that I did it too. Don't get me wrong I was nervous as **** doing it, but it paid off. I probably just got lucky. First time in my life lol
/ Yammer 2210D #15
Curious, where were you able to find the internal parts?
/ Yammer 2210D #17
JD maybe? Or ebay with the JD numbers?
I found my genuine Yanmar injectors at a farming/trucking injector specialty shop in Sacramento. That is a major base/hub for interstate trucking and there are many truck repair shops. It's also the natural supply hub supporting large scale agribusiness in California's central valley. They knew immediately which injector I needed, and had an Old Stock one on the shelf in its original 70's green-label box. They had to order the second one from a larger wholesale injector supply house that must have been nearby because they had it for me two days later.
Yanmar engines and these injectors were also widely used in the semitrailer refrigeration units mounted high on the front of the trailer where they run for days unattended, and there is the marine-engine support world using the same basic engine. So I expect engine service parts will be available for some time to come.
I've never heard if the same injectors were used by Deere.
/ Yammer 2210D #18
I thought you said you rebuilt them? Or did you replace them? And I agree these are probably common parts
/ Yammer 2210D #19
I found some of the things I needed off eBay and some for Hoye
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
AR500 Deer Target (A65640)
AR500 Deer Target...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
Sitrex 2GL-T Hay Tetter (A65640)
Sitrex 2GL-T Hay...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
