Picture behind dashboard?
/ Picture behind dashboard? #1
ArXane
Does anyone have a pic behind the rear dashboard? Im going to attempt to get the brake light lever working on my new CK3510 and want to see what it looks like behind there without taking my dash apart.
/ Picture behind dashboard? #2
This machine is fairly new. I would not attempt to take dash apart as this may void any warrantees. Contact your dealer first before attempting any DIY.
Why I asked to see if somebody else has pics :thumbsup:
/ Picture behind dashboard? #4
I understand your curiosity but I doubt anyone has pics of behind the dashboard cause this is a fairly new model if you know what I mean. Ask your dealer maybe they can help you. Just sayin
/ Picture behind dashboard? #5
An electrical diagram would let you know how the lights on the dash are wired...but good luck finding one :hissyfit: Most lights, such as a brake light, have an end switch mounted near linkage which depresses the switch when engaged. The 3510 does not have a switch installed, and would require mounting one somewhere that would physically function correctly. If you make a habit of depressing the brake pedal momentarily to release the brake before using the hst pedals, you wouldn't need a light. I do not have a service manual, but an online search might turn up how the circuit could be wired, I wouldn't try taking off the dash just to explore the possibility.
CASE INTERNATIONAL 3020-25' TERRA FLEX GRAIN HEAD (A63291)
CASE INTERNATIONAL...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A64279)
2013 CATERPILLAR...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2019 Ford Transit 250 Cargo Van (A61573)
2019 Ford Transit...
