Picture behind dashboard?
/ Picture behind dashboard? #1
ArXane
Does anyone have a pic behind the rear dashboard? Im going to attempt to get the brake light lever working on my new CK3510 and want to see what it looks like behind there without taking my dash apart.
/ Picture behind dashboard? #2
This machine is fairly new. I would not attempt to take dash apart as this may void any warrantees. Contact your dealer first before attempting any DIY.
Why I asked to see if somebody else has pics :thumbsup:
/ Picture behind dashboard? #4
I understand your curiosity but I doubt anyone has pics of behind the dashboard cause this is a fairly new model if you know what I mean. Ask your dealer maybe they can help you. Just sayin
/ Picture behind dashboard? #5
An electrical diagram would let you know how the lights on the dash are wired...but good luck finding one :hissyfit: Most lights, such as a brake light, have an end switch mounted near linkage which depresses the switch when engaged. The 3510 does not have a switch installed, and would require mounting one somewhere that would physically function correctly. If you make a habit of depressing the brake pedal momentarily to release the brake before using the hst pedals, you wouldn't need a light. I do not have a service manual, but an online search might turn up how the circuit could be wired, I wouldn't try taking off the dash just to explore the possibility.
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
2018 HINO 338 4X2 S/A 26FT CDL REQUIRED BOX TRUCK (A59912)
2018 HINO 338 4X2...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
