Plastic Toolox Question ????
   / Plastic Toolox Question ???? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I need to come up with a nice rugged tool box. I have always made them from wood. But I see there are a lot of nice weather proof plastic boxes available like this one. I stole the picture from rasorbackq's thread. Thank you. Hope you don't mind. A box like this would be better than one of my open boxes.
However, my experience with plastic stuff says that it probably won't last long outside in cold Vermont winters unless it is special plastic. How about these boxes. Can they stand some abuse in very cold weather w/o breaking or cracking ???? thanks.
gg
   / Plastic Toolox Question ???? #2
Might last for a while, but in the war of extreme cold vs plastic, cold always wins. Metal ammo cans are a cheap and durable alternative.
   / Plastic Toolox Question ???? #3
I have had a plastic toolbox mounted on my B7500 for about 10 years. It is nothing special, just a regular plastic tool box that I mounted to the loader frame. Much to my surprise it is still surviving.
   / Plastic Toolox Question ???? #4
My orange Homer Box from Home Depot lasted 3 years on my L3200 in Colorado. Was fine when the tractor sold with no noticeable UV degradation.
   / Plastic Toolox Question ???? #5
One more comment I should make ....
Be sure that the toolbox has metal latches like the one in your picture. Plastic latches just don't last long no matter what the conditions are!!
   / Plastic Toolox Question ???? #7
Last year I had business in Norway. All of the equipment up there had .50cal USA ammo cans bolted on somewhere. Some of that stuff was 50 year old. Every can was still in good shape. That pretty much summed it up for me, Won't ever buy a homer box again.
Well thanks for the replies. Pretty much 50/50. Think I'll put a small plastic box with hair pins, bushings, and small tools inside my wooden box full of heavy stuff and see what happens.
gg
   / Plastic Toolox Question ???? #9
Here is some photos of a "amo" box I added to carry choke chains in our UTV. Gosh, I do like these heavy duty, plastic boxes for jobs like this. Not sure if this is the size you need.
   / Plastic Toolox Question ???? #10
I use a large plastic Ammo box on my tractor. works very well, and weather tight!
   / Plastic Toolox Question ???? #11
As far as I can tell, nothing wrong with using plastic. It is lightweight, doesn't rust and many are waterproof. The plastic ammo cans seem to be the best choice. I mounted plastic tool boxes to both my tractors about 5 years ago. One has metal latches which have started to rust while the other is all plastic and the plastic latches are just as good as the day I put them on. I did have to do some water proofing on the solid plastic one due to lots of penetrations with handles and other things. A hot glue gun worked well for this. I do keep my tractors under a shed so most direct sunlight is blocked except for late afternoon (west side is open) but I don't know how well they would work in sub-zero conditions since it rarely gets below 15F here in winter.
   / Plastic Toolox Question ???? #12
I tried a plastic ammo box clone on my tractor, lasted about 4 months before shaking itself to pieces.
Switched to same size metal box, still doing well after 2+ years. Neither box leaked water on wet days.
   / Plastic Toolox Question ???? #13
I do not live in a cold part of the country. My tool box is a Stanley weatherproof type and is going on four hard years old. Still works great:
   / Plastic Toolox Question ???? #14
This plastic toolbox has been on for a couple years with no issues. Actually like it better than the metal one I had on my old tractor.
   / Plastic Toolox Question ???? #15
I vote for the metal ammo box myself, preferably one with a padded arm rest. :thumbsup:
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2018 Trail King Lowboy (A56438)
2018 Trail King...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2016 Doyle 10T Tender (A56438)
2016 Doyle 10T...
F -550 Bucket Truck (A56438)
F -550 Bucket...
