Running generators in parallel
/ Running generators in parallel #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
In My Ice storm/ generator lessons there was some discussion of running generators in parallel which I would like to explore further.
I've seen 10KW military gens run in parallel and am familiar with the concept of the Honda gensets that run in parallel. But now there are getting to be a number of inverter generators for relatively low cost that claim to be able to parallel. The DuroMax XP2000iS 2000 Watt Digital Inverter Gas Powered Portable Generator is going for $350 and to me having 2 would be handy.
What is the experience of TBN'ers running gensets in parallel?
How easy is it?
Is Honda that much better to justify $2K versus $700 for the same capability?
/ Running generators in parallel #2
I would not want anything to do with this. There is enough anxiety when on generator back-up already. If the military blows up two (expensive) generators and equipment, they probably laugh and requisition two more.
/ Running generators in parallel #3
If you run parallel, both gens need the same voltage, same frequency, and same phase angles. I can't imagine any $350 generator that is that smart.
Can you split your load in two, instead? Or, a 4kw genset is only 300$ or so, but no inverter.
/ Running generators in parallel #5
I'd say it mainly comes down to the reliability of the control electronics - Honda or Yamaha should get top marks. Lower cost brands.... I'd be cruising a lot of RV forums to see what stories lay there, as RVs seem to be a big target market - people want the portability of these units, as they may want the extra capacity for AC - but not bothering to set up/run 2 if not needed....
Haven't run a parallel setup myself, but if they use a link cable for the control communication, my question (regardless of brand) is - What happens if they are both running and that cable gets yanked out or cut, or becomes intermittent ?
Rgds, D.
/ Running generators in parallel #6
No problem at all doing it with a Honda "inverter" generator, they are made to do it and automatically aline themselves to each other...
The Honda 2000 is the inverter gen set, ALL OTHERS are compared to, mine has been reliable as a rock!
SR
/ Running generators in parallel #7
I guess my first question is why do you want to run in parallel? What is driving you to wanting this configuration? How much power do you need? Do you have two or more distinctly different applications like home backup and portable for camping?
I settled on the EU3000iS. It is the quietest and has longest run time of the Honda generators, it has electric start (easy for wife) and although it heavy for portable transport, it can be loaded up in your truck. Having two gens means double the maintenance.
/ Running generators in parallel #8
SR
Popular generator, for good reason.
They do require a link cable for dual operation.
Rgds, D.
/ Running generators in parallel #9
Post 3 and 6 is the key. If they are designed to do that and the gens are connected to ensure the phases and cycles are aligned it will work. Otherwise separate the loads and run two gens.
/ Running generators in parallel #10
I have 2 Smarter Tools generators I got from Costco 2 years ago. Have a parallel cable and have run the 2 in parallel several times to fire up an A/C in the 5th wheel. Two 2000w gens will out power a single 3000w. It comes down to 3200 vs 2800w. Also with 2 you can take one or both and easier to carry.
Mine is plenty quiet, powered by Yamaha engine. It can sit for several months and starts with 1-2 pulls. They are inverter gens. Honda might be first and may or may not be the best but they are the most expensive.
I have zero regrets on my purchase.
I have 2 Smarter Tools generators I got from Costco 2 years ago. Have a parallel cable and have rind the 2 in parellel several times to fire up an A/C in the 5th wheel. Two 2000w gens will out power a single 3000w. It comes down to 3200 vs 2800w. Also with 2 you can take one or both and easier to carry.
Thank you. One voice of experience is worth 10 of book knowledge.
/ Running generators in parallel #12
I have a pair of Westinghouse 2k rated running with a parallel cable and they are quiet also. The setup works fine for general purpose stuff and allows me to run a single generator for lower power items and save fuel and noise vs. running a single larger unit. But they do not have quite enough power for running a Miller 211 MVP MIG on 110 VAC at max current, which I was not expecting. I have tested them running portable electric heaters and they will operate ~ 4000 - 4500 watts. When time permits I will wire them up to the house as it is wired for generator with an 30 amp. 230 VAC circuit to the outside of the house I need to change to 120 VAC for these generators.
Someplace on this board or the welding board I read that to operate a moderate sized Lincoln they recommended 12KW minimum.
And thanks for another data point.
/ Running generators in parallel #14
I was going to past about the Costco SmarterTools inverter generator also. These a light, quiet and reliable. I used mine a few days ago to power a Shop Vac out in the corner of my field. The corner post was set in concrete and the wood post rotted out. So I vacuumed the dirt, sand, and rotted wood out in a couple of minutes and set a new post back in it's place in the concrete holder.
/ Running generators in parallel #15
To elaborate a bit on the gens that can be paired. They typically don't provide and 240v when paired- it's all 120v but double the amps. The connector cord syncs the phases instead of making them opposite- which is needed for USA 240v.
This is a bummer for folks who have 240v well pumps or other 240v devices.
Bottom line is the inverter type gens are awesome in many ways. But they are limited in that regard.
/ Running generators in parallel #16
Ooh! Good to know... was thinking of doubling up my Honda 3000 with a mate with the hope of running my well pump. I guess I hadn't thought it through. :ashamed: Well the good news I save $2000.
/ Running generators in parallel #17
Nope.
Parallel cables allow the user to obtain the full power of both units, limited by the capacity of an individual outlet. Parallel cables are available for the EU1000i, EU2000i, EU3000 Handi, EU3000i, and EU7000iS.
If you have 2 regular EU2000i or 2 EU7000iS, consider a parallel kit. The parallel kits include a built in 30A outlet (EU2000) or 50A outlet (EU7000iS), which is capable of providing the combined full power from both generators.
If you have a regular EU2000i and the Companion model, you only need a parallel cord. You will be able to use the 30A outlet on the Companion to draw the full combined power of the two units.
/ Running generators in parallel #18
Nope.
Copy and paste select parts from Honda website doesn't paint the full picture. And the "nope" comment does nothing for the discussion. My post is accurate. I know everyone isn't an engineer but a basic understanding of the difference between volts and amps is needed. You also must understand what a generator sales flyer means when it says "double" and "power".
Good luck. I'd like to see a video of the oscilloscope showing the two generators out of phase so you can make USA 240v.
/ Running generators in parallel #19
You can get a transformer to go from 120v to 240v. It would "look" different than USA 240v. Some well pumps wouldn't care- mine doesn't. If you take the time to figure out your pump that may be an option. Just remember at 240v you have half the amps.....for me I have two of the Honda 2000- one has the 30a plug. With both running and paralleled the 30a/120v becomes roughly 15a/240v.
/ Running generators in parallel #20
Understand. I need to to call my 'well guy' to remind me what exactly is my pump. I know it's on a 230v 30amp breaker but I forget the actual pump numbers.
Homemade Utility Trailer (A62613)
Homemade Utility...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
KUHN GA4121GM 11' ROTARY HAY RAKE (A64277)
KUHN GA4121GM 11'...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
