pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,431
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
I have a brand new BM19575 front mounting kit for a 4100, 4300, 4400. You can use it for a snowblower or a broom.
Well crap, looks like I need to rebuild the engine. Started noticing a whole lot of crankcase blowby and a miss. Tore the engine down (hardest part was pulling the tank, they really don't make that easy) and took some measurements. The cross hatching in all 3 cylinders looked suspiciously good. I couldn't tell if the head had been off before or not.
I'm thinking someone might have honed it in the past with stock bore when it should have been pulled and bored oversized.
I took some measurements and she needs rebuilt
Cyl. aA___aB_____bA_____bB_____cA_____cB
1 84.02066 84.02574 84.02066 84.04098 84.0232 84.0232
2 84.02574 84.01812 84.02828 84.03844 84.03336 84.01558
3 84.01304 84.03844 84.0105 84.05622 84.01304 84.03844
Hope you didn't dive into that without checking the crankcase vent. Unless it has a lot more hours than you posted when you got it, it should not need a rebuild.
Yea, crankcase vent was blowing a LOT of pulsing vapor out of it.
Got the tractor split and the engine torn down yesterday. Piston #1 is cracked. I was trying to get it started this winter with too much ether with a failed thermister/no fuel. My own fault, kicking myself very hard thank you very much. The bore is out of spec for out of round and concentricity and I'm already in this far so I have a .25mm overbore kit on order. I theoretically could just replace the piston that cracked and live with the out of spec walls, but a new piston from deere is $220 plus all the gaskets and $75 per cylinder for a ring back.
I bought an entire Maxiforce rebuild kit for less than $400 on ebay, should be here thursday and I can take the block to the machinist.
I'm also in contact with a Yanmar dealer to order 3 sets of piston squirters. This block has bosses in the casting for the oil squirters on the turbo versions so I think as long as I'm in here I might as well machine and install squirters. I'll add the "T" later on in place of the stock muffler. Everything I read says that the piston part numbers are different between this engine and the 4020tf but the pistons I took out had reliefs in the skirt for oil squirters.
Looks like your kit is right here?Oh wow, what did the compression look like with the cracked piston? Ether is great stuff, sometimes too great!
It looks like you lucked out that there is aftermarket support for your 3TNE84 engine, $400 is a steal. What all does that include? Anything on the bottom end? Maxiforce doesn't list anything for my 4400, so I'll be at the dealer's mercy if anything happens to my engine. Fingers crossed that doesn't happen.
I'll be interested to see how you go with the squirters. Does the turbo version run a bigger oil pump? A turbo 4300 would be an awesome package, if not abused.
If there's one thing Yanmar engines do well...it's start in cold weather. I used a block heater on all three Deere tractors I had with Yanmar engines...cold weather starting is easy...block heaters just make it easier. My current machine, a 2005 4520, has a Deere Powertech engine...unlike the Yanmar engines, these are cold natured (but very strong engines!)
Since the 4300 has an air intake heater (rather then glow plugs), I wouldn't use ether at all. You might be fortunate the heater didn't light off the ether
I don't know how many hours are on your 4300, but with the wear you describe, sure sounds like the tractor wasn't maintained very well.
Wouldn't the turbo pistons be lower compression?
I read where Ford put squirters on the 2011 5.0 V8s and had to remove them later due to increased oil consumption. Not sure what they did wrong on that or that it would be relevant to a diesel.
Am I crazy?
:confused3: I would just buy a new tractor but different strokes for different folks.
Larboc , could you post a link to where you got your parts from. Mine had the same symptoms so I had the head rebuilt. Against my gut feeling I did just the head ,the cylinder walls looked great. Finished assembly yesterday and still have a lot of blow by so now I start all over. How hard was the tractor split.
Did you do a compression check of the engine. Do you have picture of your cracked piston. I am thinking you couldn't see the crack from the top.
Wow that seems like a fairly big difference. I just put a new top end in my RZR and the new pistons were down in the tenths, but perhaps they match them at the factory before sending them out. How are the ring gaps?Block is done, head should be done by wednesday hopefully. Talked to the machinist and he said that one of the pistons was about .0025" larger than the other two. He just bored one cylinder a little bigger so there is good clearance across the engine. I'm glad I took him the pistons. He refused to bore the block until he had pistons in hand, and this is why.
He said it's fairly typical of service parts these days and he wouldn't have expected yanmar parts to have had a chance of being much better.
