Ford 1710 PTO Not Working
/ Ford 1710 PTO Not Working #1
char2gin
Maxwell
ford 1710
I recently bought a 1984 Ford 1710 with 4 wheel drive and a loader. The loader works fine. The PTO does not work. I can engage it with the clutch not engaged. The PTO will barely turn but you can stop it with ease. I'm not sure my 4 wheel drive is working. I have changed hydraulic filter and fluid. Any ideas?
/ Ford 1710 PTO Not Working #2
Your 4wd should be easy to see and feel if it's working (mud-snow) tires will spin easy, post a pic and have you bought manual's wich are a LOT of help for me, here's mine just got done with paint work.. ol blue.JPG
Your 4wd should be easy to see and feel if it's working (mud-snow) tires will spin easy, post a pic and have you bought manual's wich are a LOT of help for me, here's mine just got done with paint work..View attachment 506079
I bought a I&T shop manual, but it doesn't have much in the way of trouble shooting. I ordered a Operator's manual not realizing it was for an off set, so I need to order the right one. I've not had a lot of time to check it out. I'll have to remove my loader to check the clutch. Thanks for your reply.
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
Femact 9 70REV Excavator Mulcher (A66285)
Femact 9 70REV...
