New Deck
/ New Deck #1
murph1
Ohio
MF-135 DK-40se Ventrac 4500
Anyone seen or bought the new Ventrac Hydraulic tilt deck? Wanting to know any experience with it. Would have to trade my old one in.
/ New Deck
429 views and no replys. Guess I will be the first,
/ New Deck #3
I have seen some things on Facebook about it. I don't know much but would defiantly like to learn more? Is it basically the same deck with just a hydraulic lift or are there any other benefits over the older 72.
/ New Deck
The deck is different as seen in this ad Ventrac
/ New Deck #5
Murphy, your "old" mower could not be that old. I know my old back would appreciate hydraulic lift on my contour, that beast is heavy! The new series of decks are touted to be of heavier stock and better bearings/spindles. Also seem to have some design features to help avoid snagging fences or building walls.
prs
/ New Deck
prs
I called it my old one so not to confuse anyone. Never said it was a antique.
/ New Deck #7
I'd be interested in how much they give you for a trade in. Which one do you currently have?
/ New Deck
I have a 60" side discharge about 4 years old.
/ New Deck #9
Wonder if the hydraulic lift could be used on the old deck mine only has 36 hours on it....... Jim
/ New Deck
My dealer said it won't fit. My deck has 200+ hours on it.
/ New Deck #12
I guess that is what they make a welder and a lathe and milling machine for........ I'm going to get a look at one and see if I can make it work. That is about all I'm interested in, the deck cuts fine........ Jim
/ New Deck
Post some pics when you do it.
/ New Deck #14
Have to see if it is doable first, then how much it cost for the kit. It would sure make a lot easier if I didn't have to lift the deck to grease. The was what I liked about the Steiner deck, it greased from the top...... Jim
/ New Deck
Have had some problems with grass scruff coming out the front
/ New Deck #16
I seen it was not a good deal so I did trade my old (new) deck in on the new one with the hydraulic. tilt and it super it cost me money but it was worth it ....... Jim
2014 F-150 4WD (A63688)
2014 F-150 4WD...
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
Tenant T17 (A64127)
Tenant T17 (A64127)
KMC Peanut Inverter Blades (A64119)
KMC Peanut...
New Holland BR7090 Round Baler  5x6 Bales (A63688)
New Holland BR7090...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
