Canopy BX25 Cab Build
/ BX25 Cab Build
Turns out the bigger holes make things a lot easier. Here's the progress I made so far this morning.
While I'm at it, I'll throw in a plug for PPE... despite wearing a full face shield, I almost got a good shard of metal in the eye when I was cutting some sheet metal. It hit me right in the corner of the eye, hard enough to leave my eye watering for the next few minutes. Can't imagine not wearing eye protection.
/ BX25 Cab Build
Well, this is where I stopped for the day. It's a good thing I have a grinder. Slow going, but steady progress.
/ BX25 Cab Build #15
Looking good... some day soon I need to get up to Prince George. Do you know EB Horsman Company?
/ BX25 Cab Build
Well, I managed to find some time to work at the cab this afternoon. Because I'm going with regular safety glass in the windshield, and the rubber moulding can't make 90 degree corners well, I installed a 4 inch radius curve around the main windshield. A bit fussy, but good fun still. That wraps up the sheet metal work on the front... on to the closed side tomorrow. IMG_0994.JPGIMG_0995.JPG
/ BX25 Cab Build #18
Okay BC... you changed it up a bit. So you just pieced in four inside radius curves? Well done!
/ BX25 Cab Build
Thanks dragoneggs... today, I started in the right side sheet metal. I've put a solid panel alongside where the fuel filler is. My intention is to access the fuel cap from the rear door. If I had my way, I would have a fuel cap on the outside of the cab on the right side, but I haven't come up with a practical way to do that yet. Once I finish the sheet metal on the lower right quadrant of the right side, I'll be moving on to the left door. I have the basic frame built, but need to install framing for a latch as well as a structural cross brace. More to come. For now, here are a couple of photos from today. IMG_1009.JPGIMG_1010.JPG
/ BX25 Cab Build
So, I finished up the right side sheet metal today and mounted the door frame back in the left side. I had forgotten, though, that I didn't fully weld the door frame before. All of the joints were just tacked. So, instead of working on a latch plan, or starting sheet metal on the door, I spent the rest of the afternoon doing complete welds on the joints in the door frame. Here are a couple of photos from today, doesn't look like a ton of progress, but every little bit counts. IMG_1012.JPGIMG_1011.JPGIMG_1013.JPG
2012 International 4300 Reefer Truck (A61307)
2012 International...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2007 INTERNATIONAL 9200I (A60736)
2007 INTERNATIONAL...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
