bucket teeth bar
/ bucket teeth bar #1
BigDog1956
Sault Ste Marie,Mi
Ford 1710 4x4 FEL-back blade-KK box blade
Morning All, I read quite a bit and decided to order a 5ft bucket teeth bar yesterday, having a 1710 4x4 my goal is to hopefully put a little less abuse on tractor while doing work with bucket, have a box blade for leveling and smoothing dirt out-so back dragging with smooth bucket edge is not a problem, any advise ??
I ordered the TITAN bolt on model, I'm sure there are heavier duty bar's-but remember I don't have a 60hp tractor...
/ bucket teeth bar #2
The only advice I can give you is when you test fit the bar, don't forget to mark where you put the holes, then take the bar off to drill the holes. Either use lock washers behind your nuts or at least ny-lock nuts. Then forget about the tooth bar ever coming loose.
I used ny-locks on 1/2" gr. 8 bolts and an impact gun to tighten.
/ bucket teeth bar #3
I ordered the same bar last November. Came in less than a week. Had to grind down the ends as the fit was too tight. Works great for digging, made a significant difference digging a hole. However, the teeth got in the way doing just about anything else. Moving snow, back filling, moving dirt, the teeth want to dig in, and adjusting the bucket didn't work, it just rode over the dirt pile or snow.
I ended up getting a bolt on double edge blade. Kioti's come through with pre drilled holes to attach them. I know another bucket would be easier but it's a $1,000.00 .
So I just unbolt one edge and put on the other when the job calls for it.
/ bucket teeth bar #4
...I ordered the TITAN bolt on model...
I would be interested in what you think of the bar... before I found a used one, I was thinking of getting that one.
/ bucket teeth bar
Teg, I'll remember to keep you updated, they are $180, delivered on ebay it's hard to beat that, never seen a used one that wasn't beat down.
/ bucket teeth bar #6
...never seen a used one that wasn't beat down.
I got real lucky, the one I got was brand new... but I had to cut it down, less than an inch. Was actually buying something else and the guy offered it up for sale...
/ bucket teeth bar
Teg, I told you I'd update you on teeth bar-and I'll say it's a must have, I dug out and rolled boulder's that would not even fit in bucket and many other uses that when it's on you realize you could not do same thing with out the teeth, well spent $180.
/ bucket teeth bar #8
They are worth it... first time I popped a rock out of the ground, it flipped into my bucket and I thought, "This is the greatest thing"... It has never happen since then but it's still a great tool.
What about photos of it??? :D
2021 Chevrolet Silverado 2500 HD Single Cab Royal Service Truck (A64194)
2021 Chevrolet...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Titan Attachments Forks (A64126)
Titan Attachments...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
