08 montana 3840 frontend loader connection
/ 08 montana 3840 frontend loader connection #1
David V
Member
DeRidder Louisiana
LS K 5055 / LS XU 6168C
I have a 2008 ,3840 montana tractor with the straight type front end loader, ( not curved ) bought new in 08 and have only had to change water pump and the radiator, in my opinion is not bad, and it is worked hard around the farm. OK to my question l I need a hay spear attachment but my dealer I bought from says he cant find the one that connects to my type of attachment. I dont have the skid steer. Anyone have an ideal what type of connection they are called ?
Thanks
David
/ 08 montana 3840 frontend loader connection #2
That tractor should be LS built, do you have an LS dealer anywhere near you?
/ 08 montana 3840 frontend loader connection #3
Lineman, you seem to have your thumb on the pulse of Montana tractors. I'm considering buying a 2740, but someone has absconded with the portion of the wiring harness that conveys the +12V from the starter connection to the instrument panel and ignition key. A chat with any other owner or with the right dealer could help immensely. Any suggestions?
/ 08 montana 3840 frontend loader connection #4
Should be the same tractor as the Farmtrac 270, and I believe both were built by LS for each company.
/ 08 montana 3840 frontend loader connection #5
Thanks for your note. I located the local dealer who had sold the tractor originally and together we worked out that that connector had housed a fuse. I wired in a new fuse holder. FYI, a 30 Amp fuse blew when I fired up the glow plug, but a 35 Amp fuse was sufficient. Electrical problem solved, and the tractor now sits in my driveway.
2015 Lincoln MKZ Sedan (A59231)
2015 Lincoln MKZ...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2019 Dodge Durango AWD SUV (A59231)
2019 Dodge Durango...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
206320 (A57192)
206320 (A57192)
2012 Dodge Avenger Sedan (A59231)
2012 Dodge Avenger...
