Proper inflation?
/ Proper inflation? #1
Fastball
North Okanagan, British Columbia
Kubota L2900
My dad's tractor is a 4x4 L2900 with R-4 tires sized 13.5 x 16.1 on the rears.
I'm not sure if the tires are loaded - but when I was messing with the valve, liquid did come squirting out.
Anyways, I had a tire guy come over in the fall when one of the fronts came off the wheel and he pumped up the tires. But I want to make sure of the pressure. He had almost 28 psi in the rears. I see guys here taking about 14-20 psi in their rears. I knocked it down to just over 20.
What should they be at?
/ Proper inflation? #2
Sorry I'm not familiar with your tractor. I don't understand what you said in regards to tire size??
Typically on a CUT rears I would run 12-18 depending on size. Fronts I would run 16-24 again depending on size and whether it has an FEL.
/ Proper inflation? #3
On my L3400 11.2-14 AGs, just had them reloaded with 15-18 psi, the place that did them put in 20, was just a tad to hard. ("but when I was messing with the valve, liquid did come squirting out.")<<<<<If the liquid was clear-ish could be calcium, I'd change valve core's if the stuff has been in there a while.
/ Proper inflation? #4
I run all mine as soft as I can considering the machine and circumstances. For example the 33,12.5x16.5 tires on the rear of my 24 hp 1800# 2400 are rated 2600+# each at 30 psi max rating. That's 5400# of buoyance on an 1800# machine. Guess what that does to your butt and back? For me it's my comfort. The tires will just have to bear the brunt. I run those at 6-8. My other tractors are running 28" rims with ag tires (R1s) and I run them at 18 max. I think they are rated for 18 max.....check the sidewall of the tire. Lots of them tell you the max to support a given rated load which is there for your viewing also.
/ Proper inflation?
Checked the sidewall...all it gave was a max of 30-odd psi. I drove it around today at 20+ psi and it's still a tad bouncy. I'll knock it down to 15 or so and see what it feels like.
/ Proper inflation? #9
If you are moving heavy loads, you'll be at the higher end of the scale. Since that's about all I do with my tractor, both with FEL and 3-pt, I run at max. You can back off for other tasks.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
STEPP SEALCOATING MACHINE (A59906)
STEPP SEALCOATING...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
2023 CATERPILLAR 279D3 SKID STEER (A62129)
2023 CATERPILLAR...
