New Tractor, Must Do's?
/ New Tractor, Must Do's? #1
Indygunworks
Indianapolis, IN
1980 Ford 340
After rebates and tax, cash price on this guy was right near 28,500 financed through farm credit services. (to get the cash price). Grapple is a wildcat 48" root rake series E. Rear tires are fluid filled. Everything you see in the first picture weighs 5,120 pounds on the certified scales at the local grain elevator. Tractor is a Mahindra 1526.
I do plan on a PTB, and will probably get that ordered tomorrow. Since I will already be drilling into the bucket, what other modifications should I be making right off the bat?
Enjoy.
/ New Tractor, Must Do's? #2
Nice! Must dos? Keep it parked indoors!
/ New Tractor, Must Do's? #3
Congrats on the new tractor!!!! She's a Beaut!!!!!
What is a PTB?
/ New Tractor, Must Do's? #4
Must do's come up on an as needed basis. Without knowing the particular model and options, it's hard to say. Some of the mods I have done on a few tractors...
Bucket teeth.
Shid plate to protect hydraulic filter and hoses
More toolbox storage
Quick hitch hooks for 3ph
More attachments
Spaced wheels widest cause I do operate on slopes
Come up with a suitable counterweight for times when your backhoe is off.
PBT is Piranha tooth bar
Are there any good options for how/where to mount toolboxs?
Make and model are listed in the OP, but I will say it again. Its a Mahindra 1526.
Rear tires are fluid filled and probably add just under 1000 pounds of rear ballast. Is that not enough?
/ New Tractor, Must Do's? #6
Just a gentle reminder to check the torque on your wheel lugs.
Trust but verify. :)
/ New Tractor, Must Do's? #7
Congrat's on the shiny new tractor! There are literally dozens of mod's you can make to tractors nowadays, but right off the bat I would suggest adding a tool box, a fire extinguisher, and some chain grabs's on the bucket. You can get weld-on or bolt-on chain grabs now. Also, a bucket, or tube, or box to carry the chains in is quite handy too. If you think you'll be working late, then some extra lights are good too. That's just for starters. From there you can really pimp it out with all sorts of ideas found on the "Customization" and "Build it Yourself" forums. :thumbsup: Good luck!
/ New Tractor, Must Do's? #8
View attachment 504561Add expanded metal or something similar to your grill guard. It help protect the radiator, battery etc when you use the grapple.
Very nice unit.
/ New Tractor, Must Do's? #9
In order of importance:
Load tires
Grille guard screen
fire extinguisher
extra LED lights front / rear
Bucket hooks
I'd also lube all pivot points on shift linkage and similar. These are typically dry from the factory.
Do store it in a completely enclosed building if you can. Almost eliminates the aging process in my experience.
Enjoy that great looking new machine.
/ New Tractor, Must Do's? #10
When I said I didn't know the model, that was mentioned as I am not familiar with it. So I don't know it's ins and outs and weather or not things I have done to different tractors In The past would apply. Don't know what it's got for toolboxes already, or where to mount. Someone more familiar with that model will be of more help.
/ New Tractor, Must Do's? #11
I'll definitely second the "in building" storage. Not so worried about sun faded paint as the damage the sun will do to the tires and other rubber/plastic items. My tractors have always been stored in one of my carport bays. Its three sided and keeps the sun off the tractor. In 2009 when I traded in my Ford 1700 for my Kubota M6040 - the original tires on the 'ol Ford had no cracking, fading or any other damage due to the sun. I bought the Ford, new, in 1982.
/ New Tractor, Must Do's? #12
... as well as loader arms and mounts. I found about 75% of the fasteners on my new tractor needed a fair amount of tightening. Check everything.
Also, check all of your fluid levels.
Tractor will be stored in a pole barn during the summer and heated garage in the winter.
Are the rear tires being fluid filled enough rear ballast?
/ New Tractor, Must Do's? #14
Not for a heavy load on the loader or a lighter one while going down steep hills. Tractor brakes are only on the rear wheels. It's a nasty surprise to be going down hill and find that your brakes don't slow you down. Being in four wheel drive is one way to adress the brake problem but it doesn't help the rear end being too light. Weight behind the rear wheels takes weight off the front wheels (think see-saw with the rear axle as the pivot). Tractor front axles and wheels are not as robust as the rears. You can find a number of posts here about broken front axles. Weight behind the rear wheels can help that. A weight box is nice because it's compact but if you don't have one a box blade or other implement works, though it's often not as heavy as a weight box can be. I'll get a weight box one of these days. For now I use the box blade.
The rears are filled on my 3725 but I don't go anywhere without something on the back. (my property is hilly- going anywhere means hills)
/ New Tractor, Must Do's? #15
When just using your bucket, probably. When using your Grapple, not as likely.
/ New Tractor, Must Do's? #16
My dealer delivered my Massey GC1710 a while ago.
I asked: "what is the most important thing you recommend to do?"
He said: "My most important recommendation is what *not* to do. Don't loan it to your neighbor."
/ New Tractor, Must Do's? #17
The dealer makes an excellent point. There is nobody that cares as much about your tractor as you. Soon, there will nobody that understands your tractor as you do. If you are so inclined and your neighbor wants a job done - you may take your tractor to his property and do the job for him.
This "not loaning" goes beyond neighbors to relatives also. Remember, to most, your tractor is just a big toy to have fun on. They will not understand how to operate it, they have little regard for any damage that may happen and in the worst scenario they may hurt themselves or others. In the end, you will have to repair any damage done and don't expect any financial assistance from anybody in this matter.
I know this sounds harsh but it is found over & over again in posts here on TBN. It just a plain & simple fact - while most adults can operate autos - very few understand, have any experience or can operate a tractor with implements.
/ New Tractor, Must Do's? #18
most important : use it!
/ New Tractor, Must Do's? #19
With the backhoe on it, it should be enough weigh even without loading the tires. In fact my Kubota B26 OEM says not to load the tires when using the back hoe. I don't know of anyone who loads and unloads tires when not using/ using the back hoe. It wont be an issue as long as you don't try to lift the wheels off the ground although there are times when you may need to lift at least one wheel in order to level the tractor.
When moving heavy loads with the FEL, you want about the same amount of rear weight as you will be picking up. Note: you want the weight behind the rear axle-loaded tires and wheel weights do nothing for removing weight from the front axle. Actually loaded tires and rear wheel weights will allow you to pick up more weight with the FEL will maintaining rear wheel contact but it also can make you overstress the front wheels if you get too much wheel weight and not enough weight behind the rear axle. If you have the back hoe on, that is as good a counter weight as you can have. Without it, a heavy disk, bush hog or other heavy 3 PH implement works fine if you don't have a ballast box. Remember, the further back the weight is from your rear axle, the more influence it has for a counter weight (think teeter totter)
/ New Tractor, Must Do's? #20
As for things to do, check every bolt on the machine for tightness especially the wheel lug bolts and your FEL/Backhoe frame mounting bolts. IF it is hard to get too, it is more than likely loose. I found two on my LS loader frame that were up behind the fuel tank that were not even hand tight. Most bolts will stretch a bit upon initial tightening and loosen up a bit. Check when you first get your tractor and again at 50 hours and then again every 100 hours of use.
If traction is an issue, check the tire pressures. Most tractors seem to be shipped with max allowed working pressure in the tires. This may be ok for the fronts when you anticipate heavy loading with the FEL but the rears generally run better at 10-12PSI. You can verify the best tire pressure by checking the lug contact area. This is easily done if you have a flat concrete driveway or parking slab. Just dampening the concrete then drive your tractor over the damp (not standing water) and see how much of the lug is wetted. Lower the tire pressure till you have all or most of the lugs wetted.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2026 Electric Tricycle (A64194)
2026 Electric...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
