Cost to replace tires?
/ Cost to replace tires? #1
ning
Elite Member
Northern California
Branson 3520h
I'm considering bidding at an auction next week, on a '15 NH WorkMaster 33 (HST, 4x4, OROPS, 69" QA bucket) - 11 hours.
The only downside to this thing (other than other bidders making it cost a lot) to me is that it's got turf tires, and while I do have grass around here, I'd slide everywhere right now, and my main use of the tractor won't be in grass anyhow.
How much would it cost to swap tires on that? I believe the rears are 43x16.00-20, front 25X8.50-14; do tire dealers take trade-ins when they're practically new tires? :) Also - how much to fluid fill them? Round numbers are fine, of course, just a general ballpark like "between buying new R4/Ag tires (I'm not sure which would be better for me yet) and craigslisting the 11 hour turf tires, you're looking at a net of $1500" or whatever.
Thanks!
/ Cost to replace tires? #2
Tires are out of sight. Next, some of the newer sizes only come from one mfgr....Titan. Just went through it the other way...F4s to F3s. Fill charts are on the www as to size and gallons.
/ Cost to replace tires? #3
Wheels may be different and then need the correct size for the 4wd ratio.
/ Cost to replace tires? #4
Quite honestly - I'd wait and see how the turf tires are going to work for you. If you get the tractor. New tires - possibly new rims also - and Rim Guard in the new rears IS going to be expensive.
I can not relate to your tire size but mine are: front - 9.5-24, 6PR & rear - 16.9-28, 6PR. At the local tire dealer(Les Schwab) new front tires were $175-$225 each and new rears were right around $800 to $900 each. New rims - I have no idea. Rim Guard - my rear tires hold 67 gallons each = 134 gallons total. A good average price for Rim Guard is $2.50/gallon plus whatever they will charge to fill them. You will want to check on the Rim Guard price at your location - I've heard prices on TBN as high as $4.50/gallon.
I priced this combination three or four years ago and it was for Titan, Firestone & Goodyear brands.
/ Cost to replace tires? #5
I would wait and see too.^^^
While turf tires may not be ideal for your uses these new tires may work much better than you think. Could be well enough to get by without the expense of swapping. Those turf tires on the tractor are well suited for the 33 hp. tractor imo.
That is if you wind up with it.
/ Cost to replace tires? #6
May not look great, but could probably get by with just swapping the back tires. You might find someone with similar tractor that would like to have your setup, but most people want to go the way you do (turfs to something more aggressive).
/ Cost to replace tires? #7
My BIL purchased a similar sized Kubota with turf tires;they work a lot better than expected.I would try them for a while.You would have to purchase rims and tires.
/ Cost to replace tires? #8
Welcome to TBN.............................
If the turf tires are 43x16.00-20 the R4's are the same size and same rims. They will take 38-39 gallons to fluid fill them. Turfs I looked up show 41x14-20 but 43x16-20 R4's fit same rims.
Front tires also take same rims going turf to R4's.
If you switch from turfs to R1 Ag tires you need to buy rims and tires. Don't know cost of tires but they are expensive.
Dealer may take turfs on trade but won't give you much for trade in. You might make more selling them outright.
/ Cost to replace tires? #9
I bought the 2400 and sought to correct the harsh ride. One of the problems was the tires were R4s, rears were 6 ply with a heavy sidewall. Even at very low pressures they were harsh. I went with the correct sized Turf from Titan with 4 plies rather than 6 but still had a somewhat harsh ride due to stiff sidewalls....feel that the 16.5" rim dia is what is putting the tires in the heavy duty, industrial category for stiff sidewalls.
Anyway, the 4 plies did help as did the larger air volume in absorbing shocks better. I too was surprised that the Titan turf 33x12.5x16.5 (direct match for the 12x16.5 R4) that listed for about $500 cost me $290 each delivered to my Titan dealer on a truckload with other tires so I paid no freight and with farm exemption, no tax. They work as good as my R4s on traction and with the front still in R4s if I do any slipping, a little 4wd action and away I go.
I tried fluid filling but at the low pressures I run I couldn't keep it in and keep the tires locked to the wheels....slick, new, painted wheels and low tire pressures, plus liquid makes for tire to wheel slipping with any kind of traction request. So I found some weights that would fit my wheels and with a little adaptation, put them on. Working good so far.
/ Cost to replace tires? #10
You could place an ad on the ford/new holland forum and you might find someone who wants to save their yard and would swap wheels with you if you did buy the tractor.
/ Cost to replace tires? #11
Just run the turfs and buy a set of chains for running in the dirt, turfs are generally better in the snow and in mud, R4s aren't much better.
I would be completely happy with turfs but mainly I'm rolling on yard and pasture.
/ Cost to replace tires? #12
Seconds on the rears should be under $500/pair, Nebraska tire about $175 for fronts/pair
/ Cost to replace tires? #13
I would agree with earlier posters that you should just give the trufs a try. We had R-4s on our L3130, a heavy tractor vs. Hp, and turfs on our present L3400, a lighter tractor. The turfs work just fine on grass, snow or in the woods (I am selective where I drive) and sure do less damage to soft surfaces. And, having had filled rears, I much prefer a weight box. But usage may vary.
/ Cost to replace tires? #14
I just saw an ad for the same tire with 3 different vulcanizing compounds, soft, med, hard. I didn't realize you could be selective in a type/model/application. Most of the mold vent holes "skin tags" are still on my turfs. I pulled on one today and couldn't pull it off with 2 fingers. Going to bet they are made from the hard mix and that's why the sidewalls are way stiffer than a 4 ply trailer tire and the cost is on up there. Maybe that's what the 16.5 rim size did for mine. Learn something new every day.
Thanks for all the input - we'll see how the auction goes; I'll consider tires to be "probably OK as-is but possible expense".
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A61568)
2017 Chevrolet...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
WOODS TBW144 TURF BATWING ROTARY MOWER (A62130)
WOODS TBW144 TURF...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2014 Takeuchi TB228 Mini Excavator (A61567)
2014 Takeuchi...
