Can someone identify this implement please?
/ Can someone identify this implement please? #1
krazymatt
Chimayo, NM
Massey Ferguson 135
So my friend bought some implements at an auction last weekend and we cant figure out what this is certain one is for? Im assuming there is a way to post a picon this forum?
/ Can someone identify this implement please? #2
Why would you buy something if you didn't know what it was?
/ Can someone identify this implement please? #4
After you have 5 text then you can post pix.
There is the pic
Not sure what the point of this question is. I'm trying to identify a piece here not asking my friend why he bought it as that is irrelevant.
What I do know is if you put it down and drive the tractor forward it jumps up and down violently to where it could damage your hydraulics I'm thinking
/ Can someone identify this implement please? #8
So there's something like three paddles that roll over as you drive?
/ Can someone identify this implement please? #9
The interesting part is the notch added to each paddle toward the right end.
What does the handle do??
/ Can someone identify this implement please? #10
After closer inspection, there's another notch added toward the other end. Also appears to be some small notches cut into the paddles toward the center, 3 maybe??
/ Can someone identify this implement please? #11
With hillbilly engineering, there's no telling what the intended purpose was.
The handle locks the mechanism from rotating forward but it will still rotate backward if you reverse
/ Can someone identify this implement please? #14
Thanks for the answer. Now if we can just figure out why????
I'll follow this thread closely anticipating the answer. :D
/ Can someone identify this implement please? #15
Illegitimate offspring of a rolloverboxblade.jpg and a rollingbrushcutter.jpg
Bruce
/ Can someone identify this implement please? #16
Some type of light duty grading or levelling blade that was built to trip if you backed up? But I don't know what the teeth are for on the edge of the blade?
Danno
If it was some hillbilly that built he must've been an engineer because in my opinion it looks more like something that was manufactured.
/ Can someone identify this implement please? #19
Stalk cutters work like that, but are usually much lighter. Brush cutters usually have a large cylinder in the center so they can be very heavy.
It may be a roll-over rear blade that was made for where there would be frequent changes for pulling or pushing, and no angle work. Three blades needed so it doesn't get stuck horizontally mid-roll.
Bruce
/ Can someone identify this implement please? #20
Bruce
I'm guess the stalk cutter.
I have an old one with five blades.
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
Rogator RG1100 (A63688)
Rogator RG1100...
2014 John Deere 8370R (A64126)
2014 John Deere...
