Cutting down a back blade - good idea?
/ Cutting down a back blade - good idea? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
I have a 6ft Rankin back blade that I pull behind my BX. It's a bit like the tail wagging the dog. I picked it up cheap knowing it was too big but it still works okay especially on wide open flat ground if I don't bite too hard. Now that I have a plasma cutter I am thinking I should cut 6in off each end. Reason is I have a small road or more like a large path cut into the side hill to traverse down to the lower part of my property and the blade sticks out so far to the side (especially if it is offset) that it often hits the bank on the upside of the path. Any reason not to take my plasma to it? I think it will be more suited to my size tractor as well.
/ Cutting down a back blade - good idea? #2
Sounds like a good plan to me
/ Cutting down a back blade - good idea? #3
No reason at all not to modify the back blade to suit your needs. And using a plasma cutter is an excellent way to cut the blade. :thumbsup:
/ Cutting down a back blade - good idea? #4
Have to agree - shouldn't hurt a thing.
That's what I'm thinking but always nice to get a bunch of second opinions! This is moving up on my to-do list now that I can make relatively quick work of it. This will be fun! First I need to chop up my 20 year old Coleman hot tub. Thinking a chainsaw for that! Probably ought to do a video of the potential debacle.
/ Cutting down a back blade - good idea? #6
Not sure what you are using for eye protection with the plasma but I found a #5 lens seems to work the best for me. Tried a #9 and couldn't tell what was going on. Seems with a #5 I can see my soapstone lines and it is not too bright.
/ Cutting down a back blade - good idea? #7
I cut mine down with a Sawsall . Until I got to the hardened edge. Had to switch to an angle grinder with cut off wheel for that part.
I bought a cheap pair of 'over the glasses' grinding glasses and I think they are #5 but they don't fit as they stick out too much and want to fall off. I think I am going to scour Amazon tonight and see if there is a more face fitting version with cheaters built in.
/ Cutting down a back blade - good idea? #9
Just check where your attaching bolts for the cutting edge are before you start.
True... the 6in was a swag. I will split the difference on the bolt spacing and draw a line. Other than farting around on some flat stock, this will be the first use of my plasma on something 'real' and not 'lab conditions'.
/ Cutting down a back blade - good idea? #11
Dragon, good luck on your first "real" cuts; the only thing I might like better about MY PM45 is if they'd come out with the XP version BEFORE I bought :rolleyes: Still, it hasn't let me down YET, heaviest thing I've cut so far is 3/4 plate...
You may have already come up with a plan for your curved cuts, but if not here's what I do - use a straight strip of 1/4" plywood or masonite for a guide, typically 2" wide and just a bit longer than the cut - use maybe 4 large flat washers for spacers between the guide and the blade - you'll need to measure from the FAR side of the tip orifice to the part of the torch you'll use against the guide so you'll know where to place the guide -
Then clamp one end of the guide to the blade with a washer UNDER the guide (recessed enough NOT to "bump" the torch) - then more washers under the guide maybe every 4-5" as you pull on the other end of the guide, keeping enough tension on the guide so they don't fall out (convex side of the blade UP will make this easier, WITHOUT the torch lead dictating what angle your torch is at) - clamp the other end while pulling as much tension on it as you can -
IF you do this right, your guide probably won't even be singed (especially with the washers under so there's less heat transfer to the guide) - check your manual's cut speed chart and do a couple "dry runs" - you want your travel speed just a LITTLE bit slower than the chart for minimum HAZ (so you don't hafta make ANOTHER guide :D
Another thing I sometimes do - convert cut speed # to inches per SECOND, then mark the guide in SECONDS (60 ipm = 1" per SECOND) that way, in the DRY run I can practice counting (one thousand one, etc) - the torch should pass a marker every second, or you're going too fast or too slow - I know, sounds **** but it works...
Cutting edge - if its holes are equidistant, I would REMOVE it for TWO reasons - the obvious: it'll just be in the way of a clean cut, and (2) usually ONE 12" piece of cutting edge might be a more useful "resource" for another project than TWO 6" pieces...
Or, you could just FREEHAND it, and call those wavy edges an ARTISTIC FEATURE :D .. Steve
/ Cutting down a back blade - good idea? #12
You'll want a guide. The above described homemade guide will work fine.
I just use sunglasses.
Plasma Cutters are picky.
They don't like very rusty metal. Knock off the big chunks with a flapper wheel or grinder.
They absolutely don't like to be struck on solid metal. Pull the trigger with the tip off the edge, then progress into the metal. Fastest way to ruin a tip is causing the heat to reflect back into the tip.
They don't like to cut thru more than one layer of metal. You'll likely ruin the tip if you try to cut thru the moldboard and cutting edge with them bolted together. At a minimum you'll make a terribly nasty looking cut.
Remove the cutter, make a good guide, use patience. Not sure what Cutter you have so can't suggest an appropriate speed. I watch the existing material and can tell if I'm going too fast. Don't think it's possible to go too slow.
You got this, go for it.
P.S. Definitely need video of chopping up the hot tub with a chainsaw!!!! :)
/ Cutting down a back blade - good idea? #13
"Don't think it's possible to go too slow."
Too slow for me, and I end up with a LOT more slag around the cut - but I use one of these
Air Impact Hammer Kit
with the flat chisel, heavy gloves on, hold the flat side of the chisel against the cut edge and "tease" the trigger (easier to control) - run it along the edge and any slag that sticks up will be gone. If I want the edge itself smoother, a flap disk works pretty good.... Steve
/ Cutting down a back blade - good idea? #14
Yep, if speed is appropriate slag will be minimal and easy to remove.
I figured for his first time he'd be wiser to know when he's going too fast than too slow. :)
Thank you Steve and Richard for the tips and confidence. I like the template idea. I will see just how easy it is to remove the mold board. That might be too big a chore. I'm indeed the **** type so I do appreciate your suggestions. But since this is just something to drag in the dirt and rocks... I suppose an imperfect edge or two and the fact that it won't be staring me in the face, it shouldn't haunt me later. :D
Hot tub update: Ripped off the side boards and severed many of the air and water lines with my sawzall and uncovered lots of critter poop and quite the ammonia smell! Now wife has instructed me to wear full respirator with P100 filters. Luckily I have one. She also wants me to sterilize the area with beach/water solution before I start the major portion of the slaughter. I might pass on that part. I don't feel like making diarrhea! :laughing:
/ Cutting down a back blade - good idea? #16
Wow! I'm glad you explained what you were planning to do with the chain saw. Thought for a second, you were going to cut the back blade with it. :eek:
U-tube title, "Don't Attempt This". :D
Well my small chainsaw threw the chain. Did not like the fiberglass. My big saw chain dull so I gave that up after a few vertical slices. The hero was my 20v Dewalt recip saw! Here is the progress so far... taking a breather. Nasty cutting.
/ Cutting down a back blade - good idea? #18
Good guide plasma cutter hand ginder your all set...save the cut piece never know when they will come in handy.
/ Cutting down a back blade - good idea? #19
With a view like that I'd struggle to stay productive!!!!!! :thumbsup:
You'll probably want a shower after this.
/ Cutting down a back blade - good idea? #20
"You'll probably want a shower after this."
Richard, he lives in western Washington; if he stands there another 5 minutes he'll GET a shower :laughing: ...Steve
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Mack Pinnacle...
2008 GMC Yukon XL SUV (A61574)
2008 GMC Yukon XL...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
