How hard is it to repair the timer on a Maytag (Whirlpool) washing machine?
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #1
CajunRider
Cajun Land
Kioti DK45
The timer on my Maytag washer has failed. I've bought a new washer/dryer at my lady's request. Replacement timer cost is roughly $150 (They range from $137 to $240). Can the timer be repaired? The washer is fine otherwise. I just want to fix it so I can give a functioning washer/dryer set to some family in need. I might just buy the replacement timer but just check to see if I can get by with fixing it myself.
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #2
Everything can be fixed if someone is talented enough, and the payoff would be satisfying.
I had a built in microwave in a camper that crapped out. After burning out a $120 meter tester and buying a $100 in parts it still didn't work so I ended up throwing it away and buying a new microwave for $160. But I learned a lesson. Six months later I had another microwave go out in the house. This time I checked the fuses and they were alright so it went right to the burn pile.
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #3
Is it mechanical in nature or is it electronic. If electronic does it use discrete components or LSI and SMD (Large Scale Integration, in other words, one big fat IC chip, and is it Surface Mount Devices. Very small devices that are glued to the PC board and wave soldered) If LSI and/or SMD. toss it. You are never going to repair that and neither am I. If it is mechanical, you stand a chance of repairing it if you are mechanically inclined. If it is a discrete component electronic, even if it uses some IC's, if they are "off the shelf" IC's and not custom LSI then an electronics experienced person stands a chance. In other words some nerd like me. If all of this explanation seemed like ancient Aramaic or Greek to you than you have your answer. Toss it.
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #4
How do you "Burn" a microwave?
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #5
All the internal liner is plastic which will burn although not a great idea to burn plastic because some types give off phosgene gas when burning. I like to remove the magnetron magnet from them but that is about all that is salvageable from a microwave.
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #6
Some guy use the transformers for making homebrew welders.
I haven't taken it apart yet so I don't yet know. As soon as I get the new washer in I'll do that and see. The explanation is perfectly logical to me.
   / How hard is it to repair the timer on a Maytag (Whirlpool) washing machine? #9
Call the Maytag man , he is bored
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
1263 (A50490)
1263 (A50490)
2017 Volkswagen Jetta (A50324)
2017 Volkswagen...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
