Manuals- Service, owners, etc (If you need diagrams)
   / Manuals- Service, owners, etc (If you need diagrams) #41
I sent Mahindra an email today about just this issue. Here's their response:
Dear Sir,
Thank you for contacting Mahindra USA.
The Company will deploy an on line parts catalog look up shortly for all customers. In the interim, a number of dealers are using the dealer version of the catalog look up. Please check one of the dealer sites below for the information required.
Lee's Outdoor - home
J5 Tractors - Normangee, Conroe and Navasota, TX - #1 Mahindra Dealer In North America - Offering New & Used Premium Outdoor Equipment and More!
Both deploy the same lookup system. As stated, the Company sponsored look-up will be available shortly.
Thank you,
Gene Medeiros
Director – Parts Operations
Mahindra USA Incorporated
This still does not address the poorly written service manuals. I think a full parts & service manual should accompany any tractor sold by any company, so we can maintain them better & do some of the repairs ourselves, so that our tractors can stay with us most of the time. It just makes good business sense to me!
   / Manuals- Service, owners, etc (If you need diagrams) #42
One reason factory service manuals are so expensive
is the cost of paper, printing, shipping and storage.
Before they are even distributed, parts may be superseded.
If they had digital manuals accessible to everyone online,
they could be free and instantly revised and updated.
   / Manuals- Service, owners, etc (If you need diagrams) #43
It's a fair bet that everything needed to make and service tractors is created in digital form. To get from that to PDF is a simple one step process no more complicated than hitting the print button. Making it searchable is a little more work but just a little more and nothing of any significance. This much I do know from personal experence. There really is no excuse for not having documentation on-line and/or distributed on CD ROM or thumb drive.
Not that far back when you bought a piece of consumer electronics gear like a stereo component, it came with the schematics. These days it's usually a single sheet of paper with the same useless information in six languages mostly comprised of several idiotic warnings and cautions meant only to keep the corporate lawyers happy.
   / Manuals- Service, owners, etc (If you need diagrams) #44
I recently obtained electronic version of the 3510 and 4110 "New sheet metal" (circa 2004-ish) service manuals, owners manual, flat rate manual (good for pics).
I found during my last repair that diagrams and info aren't "easy" to find. Because of that, I am willing to share the occasional diagram or section, if somebody needs it.
Due to copyright, I cannot share "copies" of the manuals or post large sections at a time, but I'll help when I can.
That's it. Just looking to help out fellow Mahindra owners.
Morning,
My stepdad has a Mahindra HST 3016 tractor. He is needing a service/repair manual and needs to see a breakdown of the entire tractor. He works on everything himself. I know you cannot, as you said, give a direct copy but anything you think would be of any help to him, could you send my way? jamilla0126@gmail.com
Also, anyone else willing to throw bits and pieces my way, I would (as would he) appreciate it very much!
   / Manuals- Service, owners, etc (If you need diagrams) #45
The Mahindra 2615 is the same as the Cub Cadet 7260. You can download the manual at this link: 722-427
This is the link for the main page that lists other models as well: Cub Cadet Professional Shop Manuals
   / Manuals- Service, owners, etc (If you need diagrams) #46
I received an interactive CD when I got my new tractor. I also got one when I bought my old 4025 3 years ago. I would be asking your dealer why you were not given a manual and CD.
   / Manuals- Service, owners, etc (If you need diagrams) #47
Isn't that CD just a digital version of the operator manual?
It's not a factory service manual is it?
   / Manuals- Service, owners, etc (If you need diagrams) #48
anyone have a wiring diagram for 3616 year 2013, the selnoid clicks until finally it starts, replaced selnoid, can jump across the feild connection and it will engage the starter and start but it is a hassel.:confused:
   / Manuals- Service, owners, etc (If you need diagrams) #49
Do you mean jump from the big starter positive lug to the solenoid...???? [ old inquisitive guy wanting to help :) ]
   / Manuals- Service, owners, etc (If you need diagrams) #50
From the postive post that come from the battery to the little post, not the brush wire post:confused:
   / Manuals- Service, owners, etc (If you need diagrams) #51
Just wondered if you meant from the positive battery post to the solenoid.,.. that's where most folks have problems in either the positive/negative battery cables and where they connect to the frame/etc. Maybe you will find a partially inserted fuse or something simple. Good luck, Jerry
   / Manuals- Service, owners, etc (If you need diagrams) #52
well thanks...it just click...click...start...it's like the selnoid isn't kicking in and it isn't any safety switch because they make a differnt type of sound when you try to start and they are engaged...but thanks anyway
   / Manuals- Service, owners, etc (If you need diagrams) #53
Mine happened to be a loose wire on the right hand side. I just made sure all the connections were good and disengaged and engaged the PTO and it started up.
   / Manuals- Service, owners, etc (If you need diagrams) #54
Superb offer! Good show! :thumbsup:
I am a Mahindra 6000 owner and cannot get power steering to work properly. It appears to be overheating and fluid started coming out of steering column. Have no idea where power steering filter is, or if it should be replaced. Also, should reservoir be the problem? If so, can it be repaired or must it e replaced? Any other ideas?
The problem started when the tractor steered fine to the right, but very little steer to the left.
   / Manuals- Service, owners, etc (If you need diagrams) #55
Sounds like a bad seal in the orbital valve.
   / Manuals- Service, owners, etc (If you need diagrams) #56
I am trying to find manuals for my Mahindra 4500 4wd Serial # US 1258 J2. Owners manual, service manual, especially illustrated parts breakdown for the power steering cylinder.
   / Manuals- Service, owners, etc (If you need diagrams) #58
i am looking for a mf model 1160 electrical diagram
help please
kerry sylvester
   / Manuals- Service, owners, etc (If you need diagrams) #60
We are no longer a dealer , I cannot get the information . however Mahindra parts lookup is avail through there website. get the part number and contact a local dealer . often times markup exceeds 40%
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
207270 (A52708)
207270 (A52708)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
